Car threw a cel today.
Old Mar 1, 2006 | 11:02 AM
XkrazyAsianX's Avatar
Car Info: SGM 135i
Well, it's a misfire in the 4th cylinder. I know my spark plugs are due, could that be the problem? Anything else that i should worry about? Any input's appreciated.
Car: 04 WRX
Mods: vf34, sti injectors, walbro fuel pump, perrin crank pulley, borla headers, helix up and down pipes (catless), borla hush.
Old Mar 1, 2006 | 01:52 PM
subie OCD's Avatar
Car Info: 04 STi
How many miles? I had a misfire code (cylinder 4? dont remember) along with 2 other codes before I had my CEL fixes. This was about ~ 35K miles. My mods are catless up, highflow TBE, IC hoses and ecutek.
A friend told me it was due to the o2 sensors reading to much fuel/too hot...?? Maybe someone can explain it better. I dont know...but now that I did the 2.2k ohm 1/2 watt resistor for the uppipe and mechanical fix for the rear o2 , none of the CEL's have come back. Im at 52K miles now.
Do you have a light flyheel?
Old Mar 1, 2006 | 06:04 PM
Car Info: SGM 135i
i just hit 40k recently, i have the mechanicl o2 sensor fix for the dp, but nothing for the up, maybe i should do that ><
Old Mar 1, 2006 | 07:04 PM
Onizuka's Avatar
Car Info: 04 STi
I would ask someone about fuel rails - I remember someone saying something about one of the cylinders being the weakest, hence, the need for fuel rails.
Old Mar 1, 2006 | 09:02 PM
WREXNFX's Avatar
Car Info: 05 WRX Wagon and 08 Civic Si
you dont need a O2 fix for the up side you will screw up your fuel mixture
running a VF34 your plugs are going to go alot quicker id replace the plugs and go from there see if it happens again.
Old Mar 2, 2006 | 08:50 AM
DetailAddict's Avatar
Former Vendor
Car Info: Evo X
i had something similar. just replaced the plugs, cleared CEL, and never came back. good luck!
Old Mar 2, 2006 | 08:56 AM
lovesmysuby04's Avatar
Car Info: 06 STI WRB/Gold
Start with the plugs, of course one step colder than stock. Report back if the problem is still there. Check out www.clubplug.net
Old Mar 2, 2006 | 02:11 PM
qwk_wrx's Avatar
Car Info: 05' Evo 8
my guess is plugs also, so no lightweight flywheel then? because i think they can cause a misfire code.
sigma pi
Mar 8, 2013 03:36 PM
renosti
Mar 23, 2008 03:29 PM
XkrazyAsianX
Mar 4, 2006 10:06 AM
Keisatsu
Feb 18, 2004 03:13 PM
pyrojohnhippy
13
Jan 7, 2004 12:50 AM
