CA: Need Help. I've Killed Two Fuel Pumps in 1,500 mi. !!!
Old Feb 12, 2004 | 10:51 PM
Speed Element's Avatar
Former Sponsor
Car Info: Evo X, 04 STI, 335i, Fit
Perhaps it's something funny on the connection to the pump, sounds like it's electrical somewhere and with the pump being the only place it's been touched I would started there.
Do you have a code puller if there are still codes it may help trouble shooting a little.
Mike
(510) 487-4447
www.mpjperformance.com
www.gb-motorsports.com
Old Feb 13, 2004 | 07:37 AM
andyhidley's Avatar
Car Info: 2002 WRX
You did put the pump in the tank????
I say this because I know people that have ruined electric pumps quickly by mounting them too high.... The reason is that electric pumps wont "suck" they will only "pump". So the fuel needs to "run" into them or be really close in verticle height and from there the pump will make lots of pressure and be able to pump it up.
If its mounted too high and the pump cant pull the fuel up to the pump it will run continoulsy till it burns out.
Just food for thought...
Old Feb 13, 2004 | 10:17 AM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
Did you make sure to ziptie the pump to the housing? Maybe it's slipping off.
Old Feb 13, 2004 | 11:08 AM
andyhidley's Avatar
Car Info: 2002 WRX
I dont know how its wired. But does the pump have to be grounded? Loose ground?
Old Feb 14, 2004 | 05:33 PM
andyhidley's Avatar
Car Info: 2002 WRX
Thats odd because the pump is supposed to be in the tank. Why would the wire run all the way to the intake?????
Old Feb 15, 2004 | 05:26 PM
Yup, if you leave that ground disconnected, some quirky stuff can happen.
Maybe you just got two bad 341's? I'm sure they're under warranty, I would try another one or get a 342...mine hasn't missed a beat.
Old Feb 15, 2004 | 07:40 PM
Good luck, I guess I just got lucky when I did mine. I didn't know what I was doing but seemed to turn out ok. Keep us posted.
I have a good friend that lives on Coronado...love that place, and that bridge!
Black Shadow
Feb 26, 2004 10:06 PM
turbometrics
Vendor Group Buys/Specials
Nov 11, 2003 07:41 PM
turbometrics
Aug 26, 2003 09:25 AM
turbometrics
Engine and Drivetrain
Aug 5, 2003 07:03 PM
