bov or no bov
Old Apr 16, 2006 | 10:15 PM
BbOyPinOy's Avatar
bov or no bov
im having a vf34 setup soon.. and i was wondering if my stock recirculation valve can handle all of the boost pressure... if my stock one can handle it i wont buy and aftermarket bov.. but if i do need to.. what kind of aftermarket bov should i get??
Old Apr 17, 2006 | 12:28 AM
RedStage's Avatar
Car Info: Ver IV STi Wagon
What else are you having done?
I have VF-34, STi pink injectors, Fuel pump, Reflashed Rom, and still run stock BOV and intercooler.
Next and last upgrade would be STI intercooler, but the BOV isn't something that you'll need.
Old Apr 17, 2006 | 12:46 AM
testes1010's Avatar
the stock BPV typical fail around 18-20psi...
I replaced mine with an APS BPV...holding strong at 23psi..
Old Apr 17, 2006 | 12:57 AM
VRT MBasile's Avatar
I think the stock BPV can hold up to 21-21 PSI actually, my peak PSI (thanks to my defi boost gauge ) is something like 18.3 and I didnt hear/feel any kind of leaking
Old Apr 17, 2006 | 01:17 AM
testes1010's Avatar
mine 'leaked' (moreso blewby) on the dyno during tuning....
how you tell when the stocker fails is when boost is on target but MAF voltage does not go up as boost increases...my stock bpv failed at ~19psi...previously tuned at ~18psi w/o issues but once tuned above that, the MAF voltage would not go up....crushed the cap to get thru tuning, then replaced it with a APS BPV...no problems since..
Old Apr 17, 2006 | 12:44 PM
BbOyPinOy's Avatar
i have uppipe..turbo back.. sti intercooler.. and going to have sti pink vf34 and fuel pump installed.. and i heard the stock bov can hold up safely up to 19 psi without any leaks.. but should i get a aftermarket bov or recirculation valve??
Old Apr 17, 2006 | 05:00 PM
wow good info
dont let the post count fool you
did you do any thing to the short block ?
Old Apr 17, 2006 | 05:15 PM
testes1010's Avatar
Originally Posted by sigma pi
wow good info
Gruppe-s is building the EJ207 shortblock & Crucial has the v8 heads, their getting a P&P & 3 angle valve job along with Helix 264 cams & Helix valvetrain along w/ +1mm over valve....it should be fun...
Old Apr 17, 2006 | 11:37 PM
if you want to be lame and have your car make "that noise" get the BOV....if you want to do whats good for your car, get a BPV (recirculation).
Old Apr 18, 2006 | 12:43 PM
BbOyPinOy's Avatar
yeah i really dont care about the bov sound.. but would you happen to know any good recirculation valves?? i heard greddy made a bov that has some hardware the can make it to 100% recirculation!!
Old Apr 18, 2006 | 09:35 PM
testes1010's Avatar
APS DualVent BPV...
Greddy does make a recirc one also...
ViVaSuBy
Sep 26, 2007 03:30 PM
subiedave
15
Oct 20, 2005 07:56 AM
Kuonji
Oct 18, 2003 12:48 PM
Scooby42
Wanted
Sep 21, 2003 06:20 AM
jiveturkey
Jun 1, 2003 07:12 PM
