Bov
Old Apr 7, 2003 | 03:19 PM
misterx's Avatar
Car Info: MY 02 WRB WRX Wagon
BOV will not help perfromance. In fact, performance may be decreased.
The ECU expects to see the air released to atmosphere from an aftermarket BOV so the car will run rich for a time after it actuates. The stock diverter doesn't release air to atmosphere.
X
Old Apr 7, 2003 | 05:52 PM
ScoobyBoy's Avatar
the stock bov is more than enough for all your modding needs. it can hold up to 20 lbs of boost.
if you want the sound then go for the hks bov. its 100% atmospheric. there are 50/50 bov's. forge, and gfb sells them. they still give off the sound.
Old Apr 7, 2003 | 06:20 PM
Mulder's Avatar
Car Info: 02 WRX WRB
Your car already has such a valve. It's technically a "bypass" valve since it recirculates the released pressure back into the intake rather than "blows it off" like an aftermarket BOV which releases to the atmosphere.
The purpose of the valve is to release the pressure in the manifold when you release the throttle suddenly while under boost, this protects the turbo from backpressure which can cause the turbine to stall and ultimately damage it.
The only reason to replace the stock valve is to install one that makes noise. However as mentioned already any BOV that releases air to the atmosphere rather than recirculating as the stock one does will have a negative impact on performance. The air passing through the valve has already been metered by the MAF sensor and accounted for by the ECU, so if it is released to the atmosphere instead of back into the intake the engine will momentarily run rich.
If you are after performance save your $$ and keep the stock valve, unless you want the "bling" noise.
Old Apr 7, 2003 | 09:02 PM
Flash N Dash's Avatar
Car Info: WR Blue WRX
I beg to differ on the performance aspect of a BOV. You are going to improve throttle response and reduce the lag in btw. shifts...to me that is a ton of performance help!! I have one on my own WRX and I love it. By the way it is a GFB BOV.
I do have them for sale as well!!
The Stealth FX for GFB is one of the nicest BOV out there!! You can adjust the sound of it by the flix of your wrist and I have them in Blue, Silver, and Red if anyone is interested and all for $240 shipped!!
Super easy to install even with no skill. Should take you about 30-45 min!!
Let me know if I can help any further!!
Thanks,
Brian
Flash N Dash Performance
autransam@earthlink.net
Old Apr 8, 2003 | 12:12 AM
iLoqin's Avatar
Car Info: Nadda
I just purchased an '03 Impreza WRX Sedan. And besides all the "nececities" of gauges and such, there is this, the BOV.
So in an over all estimate... what BOV is best for performance/sound? IF there are any that gives out both.
And to "save" your turbo, it would be best to purchase an aftermarket BOV, right?
Installation process of one is how easy? (If you could e-mail me a step by step process, or guide me with a link to a site that has information on all of that, that would be nice)
After hearing about the Stealth-FX for GFB, what's great? And what is the "50/50 forge" ?
Sorry for being so noobie, and I thank all who respond and start makin' me into a green =)
Old Apr 8, 2003 | 12:36 AM
ScoobyBoy's Avatar
50/50 is a bov that vents half to the atmosphere (making the noise) and the other half back to the engine.
Old Apr 8, 2003 | 06:33 AM
iLoqin -
On which BOV is best for performance/sound, I have seen all of them that are out there and as for as quality and ease of being able to create what sound you want when you want it the GFB line of BOV's is one of the best out there!! Especially, their new Steatlh FX BOV!! No other BOV gives you the ability to turn the top to change the sound of the BOV whenever you want!!
And yes it does help to save your turbo be reducing the back pressure built up by the turbo. It also reduces the damage that might be caused when the fin of the turbo is slowed down by to much back pressure in other words it prevents turbine fin and shaft damage by quickly releasing excess boost pressure.
I can email you a detailed installation process if you like, but it does come with these instructions!! It is easy enough to install with very limited mechanical knowledge!!
And ScoobyBoy answered the 50/50 questions for you.
I hope this helps!! If you have any other questions then please feel free to ask me or email me!!
Thanks,
Brian
Old Apr 9, 2003 | 04:02 PM
iLoqin's Avatar
Car Info: Nadda
Thumbs up
Well since I'm all noobied out about my car, and the engine work done with it. I'll let you guys know when I'm plannin' to install, and anyone around Fremont, CA, (east bay of SF), would like to come help me or "watch" for experience, you're more then welcome.
Old Apr 16, 2003 | 05:26 AM
zombiedog's Avatar
Car Info: 03 WRX Stage 2ish +
Can something like the UTEC be adjusted to compensate the richness during blow off???
ViVaSuBy
Sep 26, 2007 03:30 PM
subiedave
15
Oct 20, 2005 07:56 AM
Kuonji
Oct 18, 2003 12:48 PM
Scooby42
Wanted
Sep 21, 2003 06:20 AM
jiveturkey
Jun 1, 2003 07:12 PM
