Boost Question
Originally posted by WMP
That's pretty damn impressive from the factory. Sure, EVO is at 18psi but how about STi?
The media spec for the WRX is 14.2PSI. But it seems to vary with which version of the ECU you have, how you drive, how you tuned the ECU with your right foot, where you live and how that place's temperature and altitude effect atmospheric conditions. I've head of anywhere from 11 PSI to 15PSI.
jason
jason
Originally posted by teiva-boy
Only thing is that PSI is not an indicator of performance. 14psi from one car is totally different from another car. Things like engine type, displacement, compression, turbo size etc all make up for different power levels.
.Of course, a large displacement engine can run a low-psi turbo and produce massive power...like you said, boost is quite relative to the engine.
Car Info: $200,000 sports car
I've heard from several local owners that the factory boost setting is 14 psi from spool-up to around 5000rpm, at which point the ecu drops it to around 9 psi. Several friends have added aftermarket boost controllers, set them to match the factory 14psi but NOT to drop over 5000 rpm and have noticed big power increases. The reason for the factory drop as I've had it explained to me is the stock wastegate actuator cannot hold boost reliably at much over 9 psi in the high rpm range.
How much truth is there to this?
yzercyber
Aug 12, 2005 03:42 PM
Astacun1
Jun 28, 2003 03:12 PM
mattr762
Apr 18, 2003 09:12 AM
XwrxX
Dec 17, 2002 07:14 AM
