Boost Leaking
Old Sep 26, 2007 | 06:00 PM
ho da wagon's Avatar
Car Info: 03 Wagon
Boost Leaking
My car has a upgraded turbo, a vf 30 and when i am WOT about 4000-5500 rpm my blow off is letting out boost.
i read in a forum that someone had this problem and that he was having a compressor surge. is that the problem i have?
it happens almost everytime when i am at WOT.
Old Sep 26, 2007 | 06:32 PM
AngrySubyWagon's Avatar
Car Info: ghey e-rights activist
how much psi are you runnin on the vf30?
You might not even need the BOV unless you mean the recirc valve.
But the BOV opening prematurely? Sounds like a comp. problem
Old Sep 26, 2007 | 06:33 PM
vietpunk916's Avatar
Car Info: AP1 S2k
What kinda blow off valve do u have? How much psi is your car tuned up to?
If your car have any VTA bow, suggestion to put stock bov on. If your car is running 20+ psi, get a bow that vents back into intake.
Old Sep 26, 2007 | 06:37 PM
wrxisthebest's Avatar
sounds like you need a harder spring for ur bov
Old Sep 26, 2007 | 10:22 PM
Car Info: 03 Wagon
well i am boosting 15 psi and running a HKS ss
Old Sep 26, 2007 | 10:24 PM
Car Info: 03 Wagon
maybe.idk but i want to make sure that its not a surge or boost spike
Old Sep 30, 2007 | 08:08 PM
mmboost's Avatar
If you have a catless downpipe, it might be your wastegate that's leaking.
yzercyber
Aug 12, 2005 03:42 PM
InfamousDX
Jun 20, 2003 02:58 PM
minisiu
May 22, 2003 10:52 PM
spdkills
Mar 10, 2003 08:31 PM
