boost guage installed...
Old Dec 2, 2002 | 07:30 PM
Mulder's Avatar
Car Info: 02 WRX WRB
You have to connect the boost gauge to a direct manifold connection. It cannot be ported or otherwise restricted or the gauge will not be accurate. It sounds like you may have used the line between the boost controller and the wastegate which would result in the readings you are seeing.
Old Dec 3, 2002 | 10:43 AM
Zoeb2s's Avatar
I <3 White Girls
Try using the hose off the blow off valve, thats what i use and i get pretty acurate readings.
-Zoeb
Funks
Feb 5, 2014 10:32 PM
freshrex
Aug 25, 2008 01:59 AM
JRsWRX
Mar 14, 2006 03:29 PM
rebbaz
Jan 22, 2005 08:52 PM
timl
May 25, 2003 08:33 PM
