Boost
Old Jan 31, 2003 | 05:16 PM
WickedWRX's Avatar
Car Info: Silver 2002 WRX
Boost
Hi. I was just wondering if anyone knew how much boost I can safely run with a stock turbo.
Old Jan 31, 2003 | 09:41 PM
Andersonwrx's Avatar
Car Info: '02 WRX TurboXS Stage 4
First off this question has been asked and answered hundreds of times on i-club. Try searching next time. That said I will tell you that with just a boost controller you should set it to no more than 16.5psi because the ecu will retard the timming shortly after that. I think the actual number that timming retardation starts is 16.8psi. I have mine set at 16.3psi.
Old Feb 3, 2003 | 09:42 AM
K2Skier's Avatar
Car Info: 2002 WRX/STI 2.5 liter VF22
Thumbs down
WOW, tough guy....
Old Feb 3, 2003 | 04:10 PM
mmboost's Avatar
My advice is to do what I do I have a semi-conservative gain set on my EBC with a limit of 108 kPa. My intention is 110 kPa (aka 16.0 PSI) but it can over shoot often, so I set it to 108.
Historically when I've set the boost too high or set the gain too high the timing will retard. (Not to mention boost cut off consistently kneeing me in the grown at 1.23 kPa, 17.8 PSI). So 110 kPa or so saves me all this heartache.
For more scientific data, the compressor maps for the TD04L with a turbine design similar to ours shows boost being worthless not long after 16.0 PSI. This, of course, doesn't count the addition of some sort of charge cooling beyond the stock intercooler, etc. So, beyond what's just safe for your engine, you also preserve the life of your turbo if you keep it from boosting beyond efficiency. There's not need to heat soak it so badly and no need to have it spin so furiously for so long with so much pressure when it really won't do anything for you.
Hope this helps...
jason
p.s. K2Skier - you're a helpful guy
Old Feb 4, 2003 | 09:12 PM
K2Skier's Avatar
Thumbs up
mmboost,
Don't mention it
yzercyber
Aug 12, 2005 03:42 PM
Astacun1
Jun 28, 2003 03:12 PM
mattr762
Apr 18, 2003 09:12 AM
ShokWaveRider
Feb 21, 2003 06:14 AM
XwrxX
Dec 17, 2002 07:14 AM
