blow off valves install help!!!!
Old Jun 17, 2003 | 12:13 PM
iLoqin's Avatar
Car Info: Nadda
Uhh.. put together the whole BOV and the kit.. then just bolt it on?
Old Jun 17, 2003 | 12:16 PM
VF22WRX's Avatar
Car Info: '02 WRX Sedan
First, you will need to unbolt the stock bov from the intercooler. Remove the vacuum hose off the stock bov and remove the stock bov from the return hose. You will then need to plug the bov return hose will the supplied plug (this is easier to do if you remove the intercooler). Bolt the new bov onto the intercooler and connect the vacuum hose to it. Thats all there is to it. Hope this helps. Good luck!
Old Jun 17, 2003 | 12:17 PM
Ditty77's Avatar
Car Info: 2002 WRX
and aren't there instructions anyways?
Old Jun 17, 2003 | 04:46 PM
VF22WRX's Avatar
What bov are you installing?
Old Jun 17, 2003 | 08:55 PM
dan avoN7's Avatar
2006 Mt Hammy Car Show Winner
Car Info: Black 03 WRX, White 04 E46 M3
yea you need to be more discriptive as to whether or not it's 100% atmo or recirc. Also if you just have a bov and not the flange kit you won't be able to install it, i am assuming you have the stock tmic. If thats the case and you do have the kit. Just attach the bov to the flange and unbolt the stock one. Then there should be some type of piece to put in the stock recirc hose to cap it off. Then bolt on the bov to the place where the stock one was (duh) and then attach the vaccum hose that was on the stock bov. It's really simple, i dont see where your going wrong.
xhengmanx
Feb 1, 2019 03:46 PM
Adrenalin
Mar 13, 2003 11:38 AM
Adrenalin
Mar 13, 2003 05:53 AM
Adrenalin
Mar 13, 2003 05:50 AM
