blow off valves
Originally posted by java04WRX
congrats men i just bought my 04 WRX 3 months ago and yes you can put a blow off valve on a stock motor. i bought the Gredy Type-S i will highly recomended it cost me with installation $ 170, and for the turbo timer i put the Gredy spec II it cost me $ 100 installed so look around and enjoy your car.
congrats. Nice price on both the blow off valve and turbo timer considering it is installed. Just note that the blow off valve is only 2 bolts so it can be installed with 15 minutes.
By all means and go ahead n' shut off your motor after a couple of minutes of boost on the freeway. I'm sayin' it wouldn't hurt to have one.
And about the BOV I was just answering his question. Of course there are always going to be problems with items, manufacturers aren't all perfect. A BOV can't 'cause anything but maybe runnin' a little bit rich, but it can't 'cause a break in the motor.
Originally posted by Kean
On the contrary, I have done my homework. If you read this entire thread you would understand that (check out the links). I know what turbo timers are for and the fact that the modern turbo design found on the Subaru models do not require a "cool down procedure". This means they don't need a to be "idled" therefore a turbo timer is unnecessary.
btw, regarding BOV's, I know there are designs that work well with the WRX and others that have proven to be troublesome. The choice is not as simple as you make it out to be (if you read the many posts about them on these forums you would understand). Anyone who is thinking about the purchase of a BOV would be well advised to browse the various Subaru forums to get an idea of what works best on our cars.
- Kean [/B]
- Kean [/B]
.....in the long run a BOV is still just a "noise maker" that could "potentially" cause problems (depending on the type).
- Kean
Originally posted by AzN121184
oic, so how about this type. Turbo Xs RFL??
- Kean
I agree with Kean, I also drive hard but the 1 or 2 miles before I get to my home I will take it down to bout 45 - 55 miles and drive like a granny. I figure that 5 minutes is the same as a idle on a TT. It would be cool to have a TT but I just spend the $ on a AVC-R and perrin uppipe. I am also planning on trading my car in before I hit 30K , I have 4k now '04 WRX.
xhengmanx
Feb 1, 2019 03:46 PM
Adrenalin
Mar 13, 2003 05:53 AM
