Blitz DCII DTT Question For Those Who Has It
Old Jan 2, 2005 | 02:45 PM
RU-X's Avatar
Car Info: 05 wrx
Hey guys, i just put my TT in for my 05 WRX and i was wondering... do you guys get a spike in the bost? i'll floor it and it will boost to like 1.03 then drop to .93 or .96 and then it will everyonce in a while (when floored) creep back up to 1.03 then drop agian... am i the only one with the problem? or is the turbo gauge on this turbo timer lying?
Old Jan 2, 2005 | 02:56 PM
VIBEELEVEN's Avatar
Car Info: 03 WRX
You should be well under a bar, although I've seen mine spike to a bar a couple times, but I have the stock guage so I can't be much help here.
Old Jan 2, 2005 | 03:21 PM
zumnwrx's Avatar
yes mine spikes like that alot!.. i figure its normal
edgar,
Old Jan 2, 2005 | 09:10 PM
RU-X's Avatar
Car Info: 05 wrx
OKay.... so i'm not the only one.... =) COOL MY CAR ISN'T FU*KIN UP ON ME
Old Jan 10, 2005 | 04:22 PM
Aussie Dave's Avatar
Car Info: MY06 CGM WRX STI
Yes, mine does the same thing and I have had installed for two months now and car is running fine. Just one of those things I guess..still cool product that I am still learning to play with.
Old Jan 10, 2005 | 07:41 PM
RU-X's Avatar
Car Info: 05 wrx
whats the highest ur DTT spikes up to? and when floored what does it usealy run? mines at .95ish and spikes 1.03
Old Jan 13, 2005 | 08:46 AM
RU-X's Avatar
Car Info: 05 wrx
bump?
Old Jan 13, 2005 | 10:15 AM
mmboost's Avatar
Its cold weather, and boost guages are not very accurate.
jason
Old Jan 13, 2005 | 04:41 PM
RU-X's Avatar
Car Info: 05 wrx
i know its not accurate.. but thats not the question
Old Jan 13, 2005 | 08:22 PM
MO REX's Avatar
Car Info: 02 PSM WRX
I live in St. Louis (500'above sea level) and I’ve had the TT installed for about 1.5 years. When the car was stock the readings would fluctuate a bit but I never hit over .95 hkpa (13.775 psi). My car is Cobb stage 2 now and I peak between 1.06 (15.37 psi) and 1.1 (15.95 psi) depending on conditions. If your car is stock I would think 1.03 hkpa (around 15 psi) is a bit high to be calling normal but then again I'm no expert.
BTW having car info and your location in your user profile will help you get better answers to your questions .
Old Jan 13, 2005 | 10:03 PM
mmboost's Avatar
oh yeah?
What was your question again?
I'll use your own words to re-work my original response: The turbo guage on this turbo timer is lying.
Also, you said nothing about your setup or where you tapped for vacuum
jason
Old Jan 14, 2005 | 12:51 AM
RU-X's Avatar
Car Info: 05 wrx
jason bro.... the question was...
"whats the highest ur DTT spikes up to? and when floored what does it usealy run? mines at .95ish and spikes 1.03"
the first question that i asked,
"Hey guys, i just put my TT in for my 05 WRX and i was wondering... do you guys get a spike in the bost? i'll floor it and it will boost to like 1.03 then drop to .93 or .96 and then it will everyonce in a while (when floored) creep back up to 1.03 then drop agian... am i the only one with the problem? or is the turbo gauge on this turbo timer lying?"
has been answerd
so yeah... sorry, should of just started a new topic deal.... but thanx for ur help man
OH and i tapped the vac comming out of the BOV... like 3 inches from the start of the vac line that is.
Old Jan 14, 2005 | 09:56 AM
mmboost's Avatar
has been answerd
So you never asked, "...is the turbo gauge on this turbo timer lying?" ? I could swear you did. And the truth is, you don't really know the answer to the first questions if the answer to the last one is yes. What good are reasonings based upon those readings if your boost meter is not accurate?
Tap the vacuum source off the intake manifold, not on the BOV line. Readings can be quite different and sometime inconsistent at the BOV.
jason
Old Jan 14, 2005 | 12:16 PM
RU-X's Avatar
Car Info: 05 wrx
thanx jason
Do u have any pics of where on the intake manifold i should tap?
surferdude166
Jan 20, 2004 01:02 PM
slowSSer
May 16, 2003 03:32 PM
alvyman
May 16, 2003 08:53 AM
Magerum
Feb 21, 2003 09:22 AM
KoHee
Jan 27, 2003 12:02 PM
