bigger IC = lean?
Old Aug 13, 2009 | 10:56 AM
lllRedline's Avatar
Car Info: 03 PSM WRX stg 2
bigger IC = lean?
i'm thinking about putting an STi TMIC on my bugeye. just wondering if it will run lean with larger than stock IC? thanks!
Old Aug 14, 2009 | 08:44 AM
strider327's Avatar
Car Info: 2005 WRX
You won't run lean but you won't gain much without a tune. In simple terms and a simple answer to you question, there are no ill effects with installing an STI TMIC onto your car.
Old Aug 14, 2009 | 10:57 AM
lllRedline's Avatar
ok good. i feel a bit safer now. do you mean protune or any tune? i'll be running cobb stg2
Old Aug 14, 2009 | 01:00 PM
strider327's Avatar
Car Info: 2005 WRX
Protuned.
Old Aug 14, 2009 | 01:08 PM
silverbullet415's Avatar
i ran lean before i got tuned
Old Aug 14, 2009 | 01:31 PM
strider327's Avatar
Car Info: 2005 WRX
Do you have some kind of datalog to show you ran lean? Did you have an aftermarket intake as well? Just installing a STI TMIC will not make you run lean and if you do run lean it should be a very little difference.
modwrx
May 10, 2003 05:44 PM
spdkills
Jan 23, 2003 08:07 AM
Bean
Jan 22, 2003 01:44 PM
SmuttyStyles
Jan 1, 2003 06:43 PM
Buddha
Nov 26, 2002 10:43 AM
