How to run lean w/o s-afc
Old Nov 21, 2002 | 02:31 PM
wrxnate's Avatar
get a big *** turbo and a FCD, turn up the boost...higher the boost..leaner your mixture
or you could just get an MBC and set it to 15-16psi
Old Nov 22, 2002 | 04:32 AM
scoobiesnacks's Avatar
I think it is around 350 for an apex-i s-afc
Old Nov 22, 2002 | 09:56 AM
email me at orlando_mendez@yahoo.com I have a friend who is a vendor and I can get a decent price.
Old Nov 24, 2002 | 11:23 PM
100's Avatar
100
Car Info: Blue WRX Wagon, Stage II ish, 260 whp
$290 at http://www.gruppe-s.com/
Old Nov 26, 2002 | 10:43 AM
GOT_WRX's Avatar
You are driving like a granny and found out you are running rich? Doesn't make sense. Shouldn't you be in closed loop mode what that kind of light load? (Unless you reach full boost at 3.5k RPM with TPS > 60%) In closed loop, you should be getting exactly 14.7 ar adjusted by ECU. In open loop mode you could be running rich, but you should really get gauges and be data logging to find out what's really wrong with your car before you do anything.
Originally posted by Buddha
driving style varies but 90% of the time i drive like a granny, shift at 3000-3500 rpm with some spirited driving once in a while. Get most of the pops and backfires in the low rpm range as well. And lately mileage seems to have dropped. I'm gonna reset the ECU this weekend and se if anything changes
in3g_wrx
Jun 2, 2003 10:28 AM
mazspeedpro
Apr 23, 2003 09:53 AM
CLsmooth71
Mar 24, 2003 04:38 AM
BoOm
Feb 16, 2003 10:08 PM
spdkills
Jan 23, 2003 08:07 AM
