Best order for engine modifications?
Old Jan 31, 2004 | 10:50 AM
GO24JUNIOR's Avatar
Car Info: Subaru WRX 2002
Question Best order for engine modifications?
Hey guys here is my question, I'm going to be starting to do engine modifications to my 03' WRX and I'm wondering what is the best order to do engine modifications? I want to do everything as far as exhaust, chip, up pipe down pipe, aftermarket turbo, fuel pump, intercooler everything. But what is the best order to do things please let me know thanks fellas.:banana: :banana: :banana:
Old Jan 31, 2004 | 11:20 AM
awns729's Avatar
Car Info: want a WRX
Do bolt ons first...like full exhaust...then if you have any other bolt ons in mind get them done...after that get your turbo, intercooler, fuel pump, fuel rails, injectors and whatever else and get the proper tuning at the same time
Old Jan 31, 2004 | 11:25 AM
Flash N Dash's Avatar
Car Info: WR Blue WRX
Hey sent you a PM on the exhaust parts....which I would do first.
If you are on a budget and want to do the upgrades in stages then I would go exhaust, UTEC (you can download different maps as you upgrade too)......do the turbo, fuel pump, injectors, and fuel rails(don't forget these cuz the #3 cylinder runs lean) together...depending on the size of the turbo you might have to do the Front mount intercooler also. If not then next would be the FMIC.
Now when you are upgrading all this power most forget that the stock brakes will no longer handle such power so you would need to upgrade your brakes with maybe a BBK....Stoptech makes one of the best out there!
That should get you started but if you have any other questions please feel free to ask!
Thanks,
Brian
Flash N Dash Performance
autransam@earthlink.net
Old Jan 31, 2004 | 05:26 PM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
Spend some time reading and you'll figure it out in no time.
Exhaust -> some sort of engine managment -> turbo/injectors/fuelpump -> intercooler -> new tranny -> then the sky's the limit with new fuel rails and other fun stuff...custom turbos, etc.
Old Jan 31, 2004 | 05:44 PM
sKOOTeR WRX's Avatar
chip is one of the best bang for the buck then up and downpipes. Do what ever other bolt-ons then upgrade turobs and IC and get them tuned.
Old Feb 1, 2004 | 07:32 PM
thebankman's Avatar
Car Info: subaru
Best to start with the exhaust and brakes because they're the easiest to install and cheapest. Wait to get the engine management or ecu reflash until you have all the components together. I found out the hard way and my ECU is not programmed to give more power with the exhaust i just put on. But ECUtek still makes great power on an almost stock car.
If you want insane power from the car you may want to trade in the WRX for an Sti because it comes with everything you need and more, it's a better all around package for going fast and it saves you $ in the end.
wish Sti was out when I got the WRX......
OneManArmy
Aug 7, 2013 03:32 PM
mrflame
Sep 16, 2004 01:52 PM
TimM
Feb 8, 2004 06:12 PM
gpatmac
Apr 1, 2003 08:51 PM
