Best Oil Filter?
Old Nov 4, 2003 | 01:01 PM
Jgrahn555's Avatar
Sarcastic Jackass
Car Info: i drive a beater
Use the OEM filter.
Old Nov 4, 2003 | 01:28 PM
my2003wrx's Avatar
Can't go wrong with the OEM filter. Puralator, which is the OEM filter has a filter called "PureOne" which is pretty good.
:banana:
Old Nov 5, 2003 | 08:35 AM
NewShockerGuy's Avatar
Arrow
I put on a Fram oil filter... had it on for 3000 miles... so far no problems..
-Nigel
Old Nov 5, 2003 | 08:48 AM
Jgrahn555's Avatar
Sarcastic Jackass
OEM is betta.
Old Nov 5, 2003 | 08:50 AM
ish's Avatar
ish
i usually use oem, but right now i have a fram just beacuse i wasn't able to get to a subaru dealership to pick one up
Old Nov 5, 2003 | 10:57 PM
jimr's Avatar
Car Info: 2002 WRX Sedan
Has anyone tried a Canton-Mecca cartridge filter on the EJ20 yet? I have used these for years on my race-VW motors, and they have saved my *** on the dyno once or twice when a cam lobe laid over. These are beautiful units, will replace Fram HP1 or System 1 type, they have no pressure bypass valve, are made of a very heavy cast body with aluminum cap, and special replaceable cartirdge element that you can inspect for debris. These filters are famous in the drag and circle-track world, but I don't know if there is a compatible unit for the EJ20.
Old Nov 5, 2003 | 11:32 PM
alster's Avatar
Fram super duty or if your paraniod use the Fram double super duty.
Uncle Scotty's Avatar
Re: Best Oil Filter?
Originally posted by ScoobyAdam
I have been looking forward to changing the fluid in my fiance's differentials and the gear oil in the tranny to Amsoil full synthetic which I think it a vastly superior product to many other synthetic oils out there in the market. I will evenyually change her oil from Mobil 1 to Amsoil when the car is due for another oil change. (She recently had it changed before she moved in with me so I didn't have time to stop her from having the dealer perform the work). My question is this: Which performance oil filters do you all prefer to use in on the EJ20T? Right now she is running a Subaru OEM filter. Her car is an '02 WRX wagon with the 5-speed manual. Any input would be appreciated!
There are many people who have regretted changing the gear lube in the transmission to synthetic and have gone back to plain, old, regular 75w90 GL-5 lube. It would seem that some syn fluids in the trans are too slippery and the synchro's have problems and you get the dreaded 'grunch'.
Do a bit of research prior to making the switch.
My 2¢
YMMV
I use purolator 14460 or equivalent oil filter.
Old Nov 6, 2003 | 01:50 AM
international B's Avatar
Chewwwwy
i try to stay away from the FRAM> its not even the right shape.
Old Nov 6, 2003 | 07:06 AM
ScoobyStas's Avatar
Car Info: Sonic Yellow WRX
royal purple in tranny and rear diff. Tranny runs fine, no first gear grinding. Never had that prob anyway. I almost always double clutch. Could be in the manner the tranny is treated and why it fails on some. Reverse goes in way better then before. Had it in for about 3000 miles now.
Old Nov 6, 2003 | 01:00 PM
Arrow
What do you mean?
I am changing my oil now actually, 6018 miles! :-( 18 over ... I hope that does not harm my car....
I will look at the fram compared to the new OEM oil filter that I have sitting here.
Thanks,
-Nigel
