Bad PCV Valve Symptoms
Old Aug 1, 2013 | 03:31 AM
Heedz's Avatar
Nobody likes the tuna here
On monday swapped to a catless testpipe and did an oil change...
All of a sudden when I idle for 30seconds or more I get a small puff of smoke out the tail pipe and it smells like burning oil. There is no smoke whatsoever at WOT. I just can't see an issue like this just HAPPENING.
Old Aug 1, 2013 | 04:20 AM
JourdanWithaU's Avatar
Oil in the intake?
Old Aug 1, 2013 | 09:15 AM
02RS25's Avatar
worn piston rings? oil burning under load usually are bad valve seals. IIRC. but ya, to happen all of a sudden, strange
Old Aug 1, 2013 | 10:44 AM
Heedz's Avatar
It's not under load. I'll do loaded WOT and there's no smoke.
Reason why I probably can rule out turbo seals is because if it was doing it before.... the catted to catless shouldn't change oil leak symptoms.
Old Aug 1, 2013 | 11:48 AM
FXTbrah's Avatar
previously known as wrxBRAH
Car Info: 2004 FXT
Doesnt sound related to the downpipe at all. I'd rule that out and pull off the intercooler to see if you have excessive oil in the manifold or intercooler.
Old Aug 1, 2013 | 04:27 PM
Heedz's Avatar
Okay just did a few things
Normal amounts of blow by in the intake, intercooler and cold side of the turbo.
Checked the PCV valve, it still click clacks.
Checked most of the evap lines looks fine.
Checked out the catted section of the downpipe that was removed on Monday, no signs of oils AT ALL.
Here's my conclusion.... either its......
My mix of e85 and 91 that I have been using to achieve 93 octane and just never saw the smoke before and the smell of being catless made me look, maybe it condensating who knows. I can't really distinguish the smell but I feel like there's oil in the raw fuel smell.
Hotside of the turbo is starting to go?
Crank case pressure seemed fine with oil cap removed and motor running.
Car runs perfectly fine so....... I really don't know.
Old Aug 1, 2013 | 10:11 PM
So... I guess there's no oil in the intake?
Old Aug 1, 2013 | 10:36 PM
TheFozz's Avatar
Start 'er up and let it idle for 30 minutes while you monitor the exhaust. If the smoke increases it's rings.
Old Aug 1, 2013 | 11:55 PM
Heedz's Avatar
It's not rings. No pressure or smoke from the fill tube.
Old Aug 2, 2013 | 12:27 AM
Did you check the intake?
The PCV feeds to the intake. If the PCV is an issue and it's stuck open, and you get a lot of blow-by, oil will feed into the intake. From there it will go into the engine and burn.
If there isn't any oil in the intake it is NOT the PCV valve.
Old Aug 2, 2013 | 08:08 AM
Heedz's Avatar
PCV is ruled out.
Aaron's suggestion was Valve Stem Seals.
Old Aug 2, 2013 | 12:18 PM
Superusdm's Avatar
Car Info: 2003 WRX
Driver error. Right foot not heavy enough. Whats a testpipe?
Old Aug 2, 2013 | 12:20 PM
02RS25's Avatar
Originally Posted by Heedz
PCV is ruled out.
valve stem seals will leak under load (accel) piston rings will leak under idle.
edit: i just saw u said it wasnt rings. have u done compression and leakdown test? i personally think its the rings from my personal experience. but im not here to ttell u im right and ur wrong. just throwin out possible ideas.
Old Aug 2, 2013 | 12:23 PM
Heedz's Avatar
Rings leak under load. Valve stems leak at idle and vacuum.
Old Aug 2, 2013 | 12:29 PM
02RS25's Avatar
doughnut donut. same ****. lol. thanks bro for clearing that up. then ya, id take a look at the stem seals. mine were shot and i was going through a quart every two weeks if that!
