Autometer Boost Gauge
Old Oct 22, 2006 | 11:32 PM
Jumpman23's Avatar
Car Info: 2004 PSM WRX
hey guys..im about to install my autometer [mechanical] boost gauge and i was wondering if i needed to get any extra parts..it came with the "T" fitting and nylon tube. i read that a lot of people get rid of the nylon tube and get a rubber hose for better accuracy...is this true or will the nylon tube work just as fine?
Old Oct 22, 2006 | 11:44 PM
RedStage's Avatar
Car Info: Ver IV STi Wagon
You shouldn't need anything else.
If anything I'd trust the rubber hose more than the nylon (simply because I've no idea what the nylon is capable of)
If you need a place to tap for power for the gauges lights....I went off the clock.
Also, to run the boost hose through the firewall, I used a metal wire hanger (unbent of course) and taped the boost line to the end. Pushed the hanger through from the engine bay, then went inside the car and pulled the hanger through.
hit me up if you need any advice...I've done this several times.
Old Oct 23, 2006 | 08:33 AM
silicone vaccuume line works well
Old Oct 23, 2006 | 08:58 AM
flipmode's Avatar
i have the same boost gauge and i used the nylon tube that it came with and it works fine for me.
Old Oct 23, 2006 | 05:57 PM
BillJC's Avatar
Car Info: 02 WRB WRX
My guage was kind of slow in reacting so I went to the hardware store and got some ¼" nylon tubing with the right inserts and fittings. After upping from the included tube the ¼" tube, the reaction of the guage is instantaneous. Anyway, it also depends on where you pull your signal from. I tee'd off of the BOV at the intercooler. If you do up the size, then make sure that you get the insterts for the tube as regular compression fittings will just cut into the tube.
Bill
Old Oct 25, 2006 | 11:38 AM
Silentsamurai's Avatar
Car Info: 2005 WRX IN RED!
Bill
+1 to bill's reply.
Old Oct 25, 2006 | 01:42 PM
Jake's Avatar
hm...i might want to get one soon...i dont like reading bar
Old Nov 12, 2006 | 10:03 AM
sonicyellowtech's Avatar
Car Info: 03 sonic yellow wrx
the nylon tubing works good for me, just be careful not to kink it because it kinks very easy
Old Nov 12, 2006 | 11:35 AM
Superglue WRX's Avatar
Nylon is very stong tubing and wont expand like rubber.
<<<< sells tubing and other industrial pneumatic equipment
Old Nov 12, 2006 | 02:55 PM
Noeladams's Avatar
Car Info: 2002 Subaru WRX
yea mine is the same and has worked fine for me.
gesundlich
Dec 27, 2005 05:05 PM
jimtweet
Oct 9, 2005 04:58 PM
Shaitiger
Mar 28, 2004 02:20 PM
IS300
Nov 18, 2003 05:25 PM
