Aps Tmic = Big Hp
Old May 14, 2003 | 11:15 PM
RS TURBO's Avatar
Car Info: 98 2.5RS WR Blue (breathin fire/not on fire)
Question Aps Tmic = Big Hp
Has anyone seen large HP gains after installing the APS TMIC????
What should I expect...running a bigger turbo, sti injectors, 3" turbo back, uppipe, ecutek, walbro 255lph, samco hoses!!!!!
Old May 15, 2003 | 01:42 AM
kyoung05's Avatar
From what I understand, a bigger intercooler in itself does not add much if any power, and a front mount may even cause more lag and less boost due to the extra piping (although with a bigger turbo that shouldn't be an issue). With a bigger intercooler though, I believe you can run a bit more timing advance, thereby netting you more power that way. So, if you get one make sure to get the spliiter and the hoodscoop also, and you might want to re-tune your car as you may overboost if you're running the same settings as your stock IC.
________
Volcano vaporizer
LICmotorsports
Sep 17, 2012 03:32 PM
RallySportDirect
Engine and Drivetrain
Jun 15, 2009 01:49 PM
wrx-sleeper
Apr 11, 2007 12:18 PM
ewright
20
Oct 8, 2005 11:32 AM
