Anyone with a Apexi Turbo timer... PLEASE HELP :-(
Old Sep 12, 2003 | 04:49 PM
NewShockerGuy's Avatar
Arrow Anyone with a Apexi Turbo timer... PLEASE HELP :-(
This is the SECOND one I have had... this is my problem. I am so frustrated it's not funny. I bought the HKS turbo timer harness for this because it's the same plug.. I disconnected the BLUE connector under neither the steering wheel and plugged the harness in... when I don't have this plugged in my car does not start... When I have the harness in I can turn my car on... So far so good!
Now I plugged the harness into the turbo timer.. I just wanted to SEE a diplay on it... when I turn my car to accessories, NOTHING... I get no display from this unit! This is the second one... The first one did the SAME EXACT thing but that time I had all the wires plugged in.. IE to the ECU and parking brake....
Anyone that has this turbo timer what am I doing wrong... Should I at least get SOMTHING or ANYTHING on the display when I turn the car on and it's only plugged into the harness??? I checked the harness and it's getting power to it... I checked it with my mulitmeter...
I am so angry, I don't know what is wrong. I am ready to throw this up against the wall.
Thank you,
-Nigel
Old Sep 12, 2003 | 10:13 PM
jun-wrx's Avatar
I have the same timer and the same harness. I didn't hook up the A/F feature since I read about all the problems and just too damn lazy. So I just grounded the blk wire and the unit came to life.
When timer goes, I can lock the car but the alarm isn't activated. Could this be due to the fact that I didn't run a jumper from alarm module to parking brake wire? I really never use the timer, only when the car is driven really hard.
good lock with the timer, maybe someone can answer both our questions.
Jun
Old Sep 13, 2003 | 07:33 AM
Arrow
Is it not turning on because I did NOT ground it yet... from looking at the harness there is no ground spot on it... just the ig1 ig2, and 12v.... This is the only thing that I can think of now... but if that doesn't work i am at a loss....
Thanks,
-Nigel
Old Sep 14, 2003 | 09:23 PM
Arrow
It is now working!
What happened was at scoobymods, he had the directions crossed as to the wires, we figured it out and I believe he changed it.
The red wire with the green strip is the GROUND and the white wire is the sensor! So white to white, and black to red/green wire.
It's all good now!
w00t w00t!
-Nigel
tripod023
May 3, 2010 09:24 PM
Dirty Sanchez
Dec 28, 2005 02:08 PM
A.V.E.
Jan 13, 2005 02:26 PM
gregfeder
Sep 30, 2003 11:17 AM
mikesubie
Aug 10, 2003 10:27 PM
