Anybody use water injection?
Old Jan 11, 2004 | 03:34 AM
  #76
downshift's Avatar
Car Info: dream car Subaru STi
shiv knows what he is talkin bout. dont argue just listen.
Old Jan 11, 2004 | 03:53 AM
  #77
mario's Avatar
I definately have no experience w/ tuning, Yet. but how come he hasn't chimed in on this extremely great topic?? I saw in another post where he did input his opinion slightly and said that he doesn't frequently look through these boards. But he had to see this one and noticed how many Views/ Replies it had. I believe it was Peter Head that said he would like to know how shiv feels about water injection now. Now im curious to see what Shiv has to say.
Old Jan 11, 2004 | 05:42 AM
  #78
Since Shiv is not doing much R&D on the Subaru side of things (unless STi stage II development has begun), he doesn't post here much anymore because he has nothing new to say. I imagine, however, that the Water Injection debate has begun anew at www.evolutionm.net and that you can find some new posting by him there.
downshift, I agree that Shiv knows what he's talking about. However, his powers of persuasion can be a bit lacking at times. He certainly does a LOT of research and knows as much about the theories of operation of the internal combustion engine as most OEM engineers, and his opinions are based on extensive knowledge and first hand experience. However, when his opinions on technical issues are questioned or doubted, he often gives brief defenses of them and leaves us to either agree with him or not. He's also incredibly busy, and simply doesn't have time to expound in detail why he does things a certain way. I think it's fair to say that most people educated in this field will agree with his positions, although not all. (Those of you who don't, please don't take offense to that remark.) My position on these matters is that Shiv's opinions and ideas almost always jive with what little I've learned in the past few years about how engines work and how to maximize their efficiency. I think that intelligent people who educate themselves in the manner Shiv has will almost always agree with him as well. Those who don't probably have a different perspective.
My, I digress. Back on topic, I haven't forgotten my promise to expound on my opinions regarding Water Injection. My apologies for gettign busy (and lazy ) the past couple weeks.
Old Jan 11, 2004 | 09:52 PM
  #79
Vishnu's Avatar
Car Info: 996 Turbo,Gallardo,BMW 335,125cc shifter kart,etc
wow... first time looking at this thread in a long time. If I knew that my input was requested, I would have jumped in sooner. I haven't read every post in this thread. I'm afraid I just don't have the time right now. As for my stance on WI, I am neither pro or against it since I'm sure there are applications where it may prove to be beneficial once the tuning clouds have subsided. However, I have yet to see a Subaru application which results in clear power gains through water injection. I won't argue that a water injected car may be more thermally stable, all things equal, under sustained road racing conditions. But then again, under those conditions, I recommend the use of race gas as a knock surpressant, not water. It's more expensive, but it can result in both substantially greater power out as well as improved engine efficiency (if remapped accordingly).
As for WI on WRXs, I have yet to find an application which shows substantial power gains, even through appropriate re-tuning. Interestingly enough, another tuner over in the UK, who's opinion I trust also came to similiar conclusions in EJ20 applications, despite his indirect affiliation with a leading WI company. I have my theories as to why the EJ20 is reasonably WI-unfriendly but that's all they are... theories. Again, I am sure that there are applications where WI is useful. Especially on engines which struggle on the knock threshold to run any reasonable advance numbers at max load (such as an stock EVO, for instance, which runs a measely 4-10 deg of spark advance at WOT from 3000-6200rpm.) Here, an incremental 2-3 degree bump in spark advance yeilds huge relative efficiency gains assuming the absense of knock. More than enough to overcome the power robbing attributes of displacing air and fuel with H20.
Please understand that I approach this whole WI debate from the end results on the Dyno and work backwards from there. If I can or can't make extra power with WI, I try to figure out why that is, or isn't, the case. Likewise, I don't make up my mind as to its merits of WI unless I see evidence of it on the Dyno where, as one could say, is where the rubber meets the road.
Hope that better explains my stance on WI. Please feel free to use it and experiment with it. No harm in that. I'd just encourage everyone to confirm that they are seeing the gains that they expect on the dyno. Not by noting how much more boost, or additional ignition advance they can run.
Also, I am not an expert on WI. Tuning a few cars with and without it does not tell me everything there is about it's merits. Feel free to question my notions and experiment yourselves. However, my limited experience tuning with it does provide some conclusions which need to be explained in some reasonable manner.
Best Regards,
Shiv
________
IOS GAMES
Old Jan 12, 2004 | 07:05 PM
  #83
Vishnu's Avatar
Originally posted by peter head
Shiv,
I suggest you read all the posts first before making your contribution to this thread - Please stop making sweeping statements that were not related to this thread.
I'm sorry for wasting your time. Could you please make it easier for me and concisely paraphrase the issues at hand? This would save me quite a bit of time.
Best Regards,
shiv
________
Alaska Medical Marijuana Dispensaries
Old Jan 12, 2004 | 08:59 PM
  #85
Vishnu's Avatar
Big turbo/high boost application (like the WRX running the 18G), when operating on pump gas, will often operate on the steep portion of the MBT curve. That is, every additional degree of advance you put into it, will result is substantial torque gains, all other things equal. Similarly, they can often be run at leaner AFRs due to a reduced exhaust backpressure and exhaust gas reversion/charge dillution. They also tend to run less advance (like the EVO) due to the higher mean cyclinder pressures associated with running big turbos at high boost.
Smaller turbo (stock, VF23, VF30, etc,.) applications, due to their airflow/boost limitations (which results in lower engine VE which results in lower peak cylinder pressures- all other things equal again) will operate further up on the MBT curve where things start to flatten out (that is, additional advance does not yield big torque gains). They typically seem to be happier operating at richer AFRs with substantial spark advance.
Please note that I really hate making these gross generalizations.
These two situations will result in widely different results when WI is integrated into the system. The first application will benefit more than the second. This is because the power loss associated by the air/fuel displacement and slower charge expansion rate is easily offset (or more than offset) by the additional advance one can run and the allowable fuel enleanments made possible by the in-cylinder charge cooling courtesy of H20 vaporization. That's one of the fun things about being on the steep side of the MBT curve. Anything you can do to run more advance and get a more potent charge expansion rate will result in more power.
Being on the flat portion of the curve is boring since adding more advance and leaning things out doesn't yeild substantial enough gains to compensate for the air/fuel displacement.
Just my yet-to-be-proofread 2c.
shiv
________
Oregon Marijuana Dispensary
Old Jan 13, 2004 | 10:00 AM
  #87
Vishnu's Avatar
Judging by your response, you misinterpreted, or failed to completely undestand, my post. Also peter, are you affiliated with any WI company? Every post you've made on this site has been in defense of WI as tuning tool.
shiv
________
Weed
