Alternator help!!!
Old May 1, 2008 | 06:45 PM
55superbeetle's Avatar
Car Info: 55 vw bug
Alternator help!!!
Hey guys i need your help. I swapped a silgle cam ej25 into my 55 bug and it's runnin on megasquirt. I have an alternator off i believe an ej22 single cam but im not sure how to wire it. It had a large lug that obviously goes direct to the battery and then a two pin plug with a large white wire and a small black one. I can get it to charge by applying power to the black on but it overcharges when i rev it up.Any help would be greatly appreciated!!!!!!
Here are some pics
Old May 1, 2008 | 09:32 PM
wimprezax06's Avatar
Car Info: WRX --> RX-8--〉E93
sorry i cant help you on your problem.
but damn i like your car, and i like that huge turbo, and that hanging low waste gate and that fat straight pipe exhaust. nice car. hope you will get your problem solved.
Old May 1, 2008 | 10:12 PM
FIA-WRX's Avatar
Car Info: 05 sti
First of all , holly shiat that is a nice clean set up. As for the alternator, you should check your ground and quite possibly the voltage regulator is bad. Should however start with the wiring first.
jerole17
Jan 21, 2010 02:42 PM
.:: 808 STi ::.
Sep 3, 2004 05:57 PM
jewpac42
Jul 30, 2003 06:34 PM
Jalapeno Man
May 26, 2003 09:29 PM
Kevex
Nov 24, 2002 12:44 PM
