500 miles too soon for 1st oil change?
Old Dec 23, 2003 | 12:56 PM
Uncle Scotty's Avatar
Wait 'till 1500.
And I wouldn't use syn untill 5k miles.
Old Dec 23, 2003 | 02:45 PM
AzN121184's Avatar
Car Info: civic
there's really different opinions on when the frist oil change is. Some people believe tehy use a special type of oil in the car when u first get it, and u shouldn't change the oil until 3000. Just go easy on the car and u'll be fine, besides break in period is 1000miles anyways
Old Dec 23, 2003 | 03:56 PM
WRX Rush's Avatar
Car Info: Stage 4+ Bugeye
My thought is that if your engine breaks in by 1,000 miles then all the metal debris should be in the metal by then or most of it. I changed mine at 1,000 and it is going perfect. It is your choice, I don't think you can do it too early really, so yeah if you wanted to you can do it at 500. Good Luck
WRX Rush
Old Dec 23, 2003 | 07:01 PM
AzN121184's Avatar
Car Info: civic
from what i know, my uncle who is a mechanic and works on cars told me usually he doesn't recommend the first oil change unless it's 3000. ON the other hand, some cars like Mercedes and such tell you NOT to change the oil until 10,000
Old Dec 24, 2003 | 12:32 AM
WindingRoad's Avatar
Car Info: 2004 White GDB
i got mine changed after the first 1000. i used the subaru oil filter also. i have taken apart my old oil filter and there were no metal shavings to be found
Old Dec 24, 2003 | 07:23 PM
1fastGC's Avatar
Car Info: Evolution VIII
don't change it til 3000 miles. use dino oil til the car is properly broken in (around 10,000 miles) then switch to synthetics.
Old Dec 25, 2003 | 10:25 PM
my2003wrx's Avatar
Aren't they too small to make out?
:banana:
Old Dec 25, 2003 | 10:28 PM
Magish's Avatar
As stated above, 1k is the best for 1st oil cange then synthetic at 5k is what I do at least.
Old Dec 25, 2003 | 10:37 PM
Zoeb2s's Avatar
I <3 White Girls
I didnt change my motor oil till I hit 3K miles
Old Dec 25, 2003 | 10:41 PM
DarkAngel's Avatar
you know everyone has different throughts on this. Everyone seems to agree that you should not use Synthetic until couple of oil changes and as for the first oil change I would go by the owner manual. I am pretty shure they would know what is best for the car.
Old Dec 26, 2003 | 12:38 PM
wrxn'sx's Avatar
Car Info: 03WRX=sold 08STI=newhotness
I changed out the stock oil at 1200, with dino. Changed again with dino at 3300. Changed to synthetic at 7400. No blowby or missing oil yet, butl I'm only at about 10k now.
I do check out the canyons in the upper range of my RPM band frequently.
Old Dec 26, 2003 | 10:02 PM
IcemanSS454's Avatar
Car Info: 2004 WRX Sedan 5spd
Along these lines has anyone experienced oil burnoff while the car is breaking in. I know that certain performance cars like the M3 guzzle oil until the motor is properly broken in. Is this something I should keep an eye on or does the wrx not experience this?
Old Dec 26, 2003 | 11:27 PM
Max Xevious's Avatar
BanHammer™
Car Info: 2014 Forester XT
I never saw excess burnoff on my break-in, dunno about anyone else tho... anyone ? ... anyone ??
