3" catless or 2.5" w/cats
Old Dec 24, 2002 | 05:43 PM
DWNSHFT's Avatar
Car Info: 03 sedan 2nd wrx
what is the better set up a 3" w/out cats or 2.5 w/cats
I will have the fac. turbo unit TXS chip up pipe
what do, you guys think I should buy 3 or 2.5
thanks
Old Dec 24, 2002 | 07:01 PM
BongMan's Avatar
Car Info: '01 RS BRP
Post
i think the 3" catless will be faster.
Cops are the only reason catless is a bad thing.
Old Dec 24, 2002 | 09:25 PM
Steppin Razor's Avatar
@Stoptech
Car Info: 2002 WRX Wagon
Yeah, the 3 inch catless will definitely give you a bit more top end but I'd be willing to bet that with your setup the 2.5" would give you a wider torque band (read: better for everything except the 1/4 mile) and would keep you out of trouble with the po pos because of the cat.
Old Dec 26, 2002 | 07:44 PM
big sky's Avatar
Car Info: 04 GGA+
I'm running a 2.5" turboback (scoobysport) w/ the 3rd oe cat (front midpipe). I had to leave (or replace) one cat for scca classifications. I chose to go w/ 2.5" for the wide torque curve and better low/mid range torque, it also enables me to utilize the 3 rd oe cat. I don't plan on turbo upgrades as I need the quick spooliong TD04. Alot of it comes down to what you want to do w/ your vehicle.
big sky
Old Dec 27, 2002 | 04:53 PM
palaban's Avatar
Car Info: G35 Coupe (FOR SALE)
3" w/out cats or 2.5 w/cats?
Does anyone how big the performance differences are between the two? Is there a noticeable difference? Dyno charts would be great, but butt dyno comparisons are fine too.
Old Dec 27, 2002 | 05:45 PM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
2nd fastest suby here on the island with one hi-flow cat on my car
Is that enough for you palaban? Lets put it this way, you wont notice a difference whether you have a cat or not.
Old Dec 27, 2002 | 07:17 PM
big sky's Avatar
Car Info: 04 GGA+
You mention cats plural- any system w/ cats in plural will pale to a catless system. If you make that singular and stipulate that the remaing cat is the 3rd oe cat or a high flow unit, the difference becomes small- 2 1/2 or 3".
The choice between 2 1/2" vs 3" is (used to be anyways) a pretty hotly debated subject. Again if I was going to stick w/ the oe turbo, 2 1/2" would be (is) my choice.
Getting rid of cat #1, 2 is probably the most important consideration in any exhaust upgrade- this frees up the most ponies.
big sky
Old Dec 27, 2002 | 08:17 PM
palaban's Avatar
Thanks tevia boy. I was thinking about being a tree hugger, but with all you upgraded turbo guys running around, I'm going to need all the help I can get.
Good luck at the track. Let's hope you're not 2nd fastest for long.
Randman
SoCal Classifieds
Mar 19, 2007 01:01 PM
gesundlich
Oct 30, 2005 10:09 AM
WRX Rush
Oct 19, 2004 06:22 PM
