3/16ths mod???
Old Mar 25, 2003 | 08:47 PM
Dick Fitzwell's Avatar
most noticeable gains with this mod are with basically stock cars. i have yet to find anyone w/mods that was able to notice a difference with this.
Old Mar 25, 2003 | 09:43 PM
Steppin Razor's Avatar
@Stoptech
Car Info: 2002 WRX Wagon
it's tempting to do this mod but in my opinion, it is totally and utterly worthless. i had it on my car for several months and didn't notice any difference. then i took it off, noticed no difference, and was very glad to have it off. if you want to spend time on your car, wax it.
Old Mar 30, 2003 | 01:57 PM
vincent's Avatar
Car Info: 2003 wrx impreza wagon silver
boost restrictor mod.
i tried this mod on my 03 wrx wagon. I have factory boost gauge. factory restrictor is brass i replaced with a 3/16 restrictor, plastic with brass insert. Am i correct in replacing with another restrictor or should i be using a straight thru coupling/vacuum connector? Either way the opening is bigger and absolutley zero gain has been achieved. Before and after the mod i CANNOT reach boost levels of over .09 in any gear!! Alittle frustrated here, all help welcomed. Thanx
Old Mar 31, 2003 | 01:41 PM
vincent's Avatar
3/16 mod corrected thanx
I truly am a dumb-***. I was on the wrong side of the intercooler, where i did find a "T" w/ single hose off the "T" containing a tiny brass restrictor which i replaced with a 3/16 coupling...duh. This hose was connected to a themastst(i think) which was connected to the front left part of intercooler . Any idea what it is? As a result no damage nor noticable affect occured
In conclusion i found the right location. Immediatley noticed a difference, went from .09 to .1 boost. Now i guess i should reset ecu then redline rpm's and teach teach the computer to be more responsive and aggresive. Thanx again
Mobutusan
Apr 2, 2008 11:38 PM
T-Will
Jun 20, 2007 09:24 PM
