20 psi on a td06-18g??will it be safe?
Old Oct 20, 2003 | 01:04 PM
drwrx's Avatar
You may be pushing the limits of the STi Injectors. To maintain that level of boost all the way to redline you may have to jump up to 650 or 800 cc injectors. But beyond that . . . if by "re-tune" you mean on a dyno with some diagnostic tools keeping track of your egt, air/fuel mixtures and knock sensor than yes I see no reason you can't run 20 lbs of boost. The 18g can support that boost level, but you may want to keep a close watch on your numbers closely. A buddy of mine had his Eclipse dynoed with an 18g and found only modest HP and Torque gains over 18 lbs of boost, but his egts increased significantly and his knock treshhold was much narrower. Most Turbo charged cars perform best near their knock threshold, but the risks do increase.
Old Jul 19, 2004 | 10:35 PM
Uncle Scotty's Avatar
emanage is NOT real EM for your car....a TD06-18G is a no foolin turbo that will pop your motor in a half a heartbeat if you let it.
Get yourself some REAL EM and get it tuned right, and you shouldn't need 20psi for fun.
The STi injectors may be too small unless you do the FPR 'mod'(crush the top) to increase pressure and thus flow...but the tune is all important.
Old Jul 20, 2004 | 12:17 AM
RAGE's Avatar
Car Info: 07 limited
I agree.... nuff said!
SR20steve
Sep 10, 2008 01:43 AM
4080wrx
Hawaii Classifieds
13
Jun 27, 2008 12:10 PM
4080wrx
Oct 31, 2007 01:46 PM
VRT Gump
24
Feb 17, 2007 04:34 AM
triguy
Feb 4, 2007 11:00 AM
