2.5" vs. 3" exhaust
Old Nov 27, 2002 | 10:42 AM
1fastGC's Avatar
Car Info: Evolution VIII
If you want to retain some low end torque, go w/ 3" downpipe and w/ a 2.5" catback to gain some mid/top hp.
Old Nov 27, 2002 | 11:00 AM
stealth-wrx's Avatar
specialiest say that all you need is to got 10 percent larger then the turbo exit hole. technically you could you 2 3/8 - 2.5 but thats has no cool factor
Old Nov 27, 2002 | 03:26 PM
Scubaru's Avatar
Car Info: MY02 GD WAGON, MY87 AW11
Originally posted by bone324
Okay, it looks like 2.5" is the winner for my setup. I'd rather have torque at the low end than hp at the top. Thanks.
That's what I would think too. But, www.spdusa.com claims that a certain amount of backpressure is required for the turbo to spool quickly and 3" does not produce the "ideal" backpressure.
I read that too. you would think that NO restriction woould allow the turbo to spool faster. Hmm...
-scu
Old Nov 29, 2002 | 03:41 PM
josh's Avatar
Car Info: 2016 CWP WRX
hey all
on my old rex wagon, i originally used a apexi old skool turbo back. the dp was non-bell mouth. the entire system went from ~73mm to 80mm as it exited into the muffler(if you could call it a muffler). i found a huge increase in torque and a appreciable increase in hp. alot less lag, and faster spool.
i am repeating others, but if you want lots of top end and huge hp #'s go big (like even 4"_. i prefer the torque over hp, especially down low, and therefore would stay at 2.5-2.75 or taper it in either direction from 3"-2.5 or like the apex i had.
but someone really hit paydirt when they said to free up restrictions. that alone on my car made all the difference, in both drivability and performance. vishnu uppipe and catless exhaust (a;though shiv would argue a cat makes just as much or more power) makes the turbo work alot less and allows air to move through faster. and in the end, that is the bottom line. squish and squeeze more air through the motor.
josh
itzpoorboy
Jul 2, 2012 09:12 AM
itzpoorboy
Jun 15, 2012 10:03 PM
itzpoorboy
SoCal Classifieds
Jun 14, 2012 01:55 AM
jyhighsky
Jan 25, 2006 10:02 PM
