1/4 Mile times for WRX
Old Oct 26, 2003 | 04:25 PM
jreat's Avatar
Car Info: 2002 WRX and 2001 Mercury Cougar
There is this guy that thinks that he can run 12's in his WRX. Is this possible with the following mods?
3 inch Turbo back exhaust - catless
3 inch uppipe
manual boost controler at 18 psi on the stock turbo.
I don't this it is but then again I am not an expert.
Old Oct 26, 2003 | 04:40 PM
Brfatal's Avatar
Technical Know-It-All
Car Info: '02 WRX + '15 WRX
No.
Old Oct 26, 2003 | 05:35 PM
Tell him to turn the boost back down to 16.5 until he gets real engine management. In the meantime he should be in the mid to high 13s.
Old Oct 26, 2003 | 05:41 PM
ish's Avatar
ish
yeah, not smart to run 18psi
Old Oct 26, 2003 | 05:52 PM
jreat's Avatar
I know I have read that anything over 16psi is dangerous. He says it is on 16, yet today because of the colder air he said he was pushing 18 the whole time.
Old Oct 26, 2003 | 08:54 PM
BoOm's Avatar
IBFUELCUT
Old Oct 26, 2003 | 11:38 PM
in3g_wrx's Avatar
Car Info: white 03 sedan
wow! really? a 3 inch uppipe? what company makes 3 inch uppipes?
Old Oct 27, 2003 | 10:43 AM
4080wrx's Avatar
dont believe the hype a 3in up pipe would lose to much back pressure and velocity.
Old Oct 27, 2003 | 02:53 PM
jreat's Avatar
I have the Turbo XS uppipe and the inter diameter is just under 2 inches.
Old Oct 27, 2003 | 05:13 PM
in3g_wrx's Avatar
2 inches is reasonable....3 inches is very hard to believe...like what jess said^^^
Old Oct 27, 2003 | 05:54 PM
namakemono's Avatar
Car Info: gc w/ neons and a wrx that needs neons
no powered by stickers right?
Old Oct 27, 2003 | 07:37 PM
The turine inlet is 45mm, so anything bigger than that is costing you spool but still not gaining top end. There's a reason all uppipes look about the same size.
Old Oct 27, 2003 | 11:45 PM
Daredevil's Avatar
helix is about 2 inches, its what i got, yea pointless post
Old Nov 15, 2003 | 11:01 AM
phucvtec's Avatar
Car Info: 2003 Subaru Impreza WRX
So... I have the following:
vishnu turbo back, dual tip (not signature series)
K@N pannel filter
Cobb state 2 reflash, V1.08
93 octane fuel, 40 degrees F on average
What 1/4 mile time should I be putting up? All the darn tracks are closed here, cause it already snowed a bit. Beat.
Old Nov 15, 2003 | 11:40 AM
Ex-ricer's Avatar
Car Info: 180sx super drift machine!
mid to high 13s...more likely mid...and to reiterate the above post...fuel cut is at 17.1psi or there abouts so if your man is at 18psi either hes lying to you about his shizzle or hes just a moron jk...i think
josh
