02 WRX Turbo boost problem. help.
Old May 25, 2008 | 11:16 AM
yanimaya's Avatar
Car Info: 02 WRX wagen
hi guys, i have just bought my 02 wrx wagen from some local dealer. and it have a used turbo on it, i can tell it is from junkyard with those yellow marks on it, and when i try to boost it, everytime it will only get .04 or .05 mPa = 7 PSI, that is both of my boost gauges reads, so is that my turbo did not adjust right or boost controler has problem? everything in my car is still stock. please let me know if you guys has any idea what makes the car only can run in 7 psi. thx.
Old May 25, 2008 | 12:28 PM
wrxisthebest's Avatar
the waste gate actuator rod arm... if it looks like alot of threads or a couple... it should show a couple.. not the entire set of threads...
Old May 25, 2008 | 12:33 PM
yanimaya's Avatar
cool, i try to adjust it after my car cools down, thx for your tips.
Old May 25, 2008 | 12:41 PM
if anything... take away threads.. so ya.. make the adjusting nut go closer to the waste gate actuator, and follow the nut with the actual attachment...
if this doesnt improve anything, go back to where it was.
so REMEMBER HOW MANY TURNS U TURN IT!!!!!
Old May 25, 2008 | 12:53 PM
Shazam321's Avatar
Sounds like your boost control system isn't hooked up right.
Should look like this at the turbo. The black ring on the hose coming to the T is the restrictor pill.
Old May 25, 2008 | 12:58 PM
good point!
restrictor pill needs to be on the turbo side of the T
Old May 25, 2008 | 12:59 PM
Shazam321's Avatar
Don't adjust the wastegate arm that isn't your problem. Your car is running wastegate pressure because the boost control system isn't hooked up right or is missing components.
Old May 25, 2008 | 01:10 PM
yanimaya's Avatar
well, i just compared the picture and my car, the restrictor pill is still there and all hose hooked up, the electronic controler's wire connector is connected. so hmmm that part pretty much wasn't the problem there, what i am thinking is that possible cause by a old boost controler or carbon stuck inside the boost controler valve?
Old May 25, 2008 | 01:11 PM
Shazam321's Avatar
You have an electric boost controller?
Old May 25, 2008 | 01:12 PM
i think he means the Boost control solenoid... the stock one??
umm... not likely...
Old May 25, 2008 | 01:24 PM
yanimaya's Avatar
right. everthing in stock.
Attached Thumbnails 02 WRX Turbo boost problem. help.-.jpg   02 WRX Turbo boost problem. help.-b.jpg   02 WRX Turbo boost problem. help.-c.jpg   02 WRX Turbo boost problem. help.-d.jpg
Shazam321's Avatar
For the stock boost solenoid you have 2 lines going into it. The line coming off the turbo inlet goes into the side of the solenoid and the line coming from the turbo goes into the bottom of the solenoid, make sure those are hooked up right.
Old May 25, 2008 | 01:32 PM
yanimaya's Avatar
those 2 lines are right too.
Old May 25, 2008 | 01:52 PM
Shazam321's Avatar
You got me stumped. Its a guess but maybe you have a vaccum leak or there isn't enough voltage going to the solenoid, you might have a crack in the intercooler hosing. Might be a vaccum leak going to the gauges. If you have a warrenty (might not since its an 02) take it in.
You could trying posting this on nabisco. They might be able to help more than I can.
Sorry I couldn't help you find the problem.
P.S. your missing your turbo heatsheild.
Old May 25, 2008 | 03:34 PM
yanimaya's Avatar
i have check for leak, that intercooler really have crack, which is hit my rocks from the top. it crack from the hit vent. i will get a new intercooler asap, thanks for all the information to help me out guys. thank you million times.
