02 Wrx Random Misfire
Old Jan 15, 2006 | 02:05 PM
wrx81's Avatar
Car Info: 02 WRX
i have been getting a random misfire code for a couple of mths now. It started happening after i installed (uppipe, boost controller, clutch and flywheel) i dont see why any of these things would cause this problem. I would like to hear any comments or better yet cause and fix????? i have changed the fuel pump, plugs and disconnected the utech to try and resolve the problem...
Old Jan 15, 2006 | 02:10 PM
atreger's Avatar
Car Info: 02 WRX, BLACK
How many miles on your car? Might be a coil pack going bad.(happened to me). They are easier to change than the plugs.
Old Jan 15, 2006 | 02:58 PM
wrx81's Avatar
Car Info: 02 WRX
The car has 80000 on it. However i believe that if the problem was the coil pack then the code would be confined to those cyclinders all the time. the problem is that the code is for a different set of cycliners all the time. When the code is cleared it comes back withing a couple of hrs. How did you check your coild pack?
Old Jan 15, 2006 | 03:15 PM
atreger's Avatar
Ohh, well my cel code was specifically for cyl #3 so it was pretty easy. But it was around 80,000 when mine went out. Those Utecs are tricky, I used to have 1 and had all sorts of issues, then switched to a ECUTEK reflash and didn't have many problems. Did you tune your utec yourself?
Old Jan 23, 2006 | 07:00 AM
Wildblitz1337's Avatar
Car Info: 89 honda civic (sedan)
Ive got random misfires too...act light flywheel, 3" turboback catless, catless uppipe, cai, perrin crank pulley, and greddy bov. I think the lightweight flywheel and crankpulley might play a part in random misfires, but not 100% about that. Im about to get a computer in about 2 weeks, so hopefully i can resolve the issue w/ that.
Old Jan 23, 2006 | 07:15 AM
Egan's Avatar
It's the flywheel in both cases.
Astafyev26
Mar 7, 2016 11:56 AM
soggynoodles
Jun 28, 2011 06:50 PM
aznsexrboy808
Hawaii Classifieds
Feb 6, 2009 04:31 PM
jrushlow
Sep 27, 2005 06:47 AM
