Random misfire only at idle solved
Old Sep 25, 2005 | 05:24 PM
jrushlow's Avatar
I finally solved my random misfire that was only occurring at idle. Hopefully this will help someone else. The issue was that my timing belt had skipped one tooth. The rear driver's cam cover was cracked and a piece of it fell into the timing case causing the belt to jump a tooth. No more misfires in the past 3 weeks. HTH.
-Joe
Old Sep 27, 2005 | 06:32 AM
ralli me's Avatar
Random misfires only at idle solved
thanks. something else i have to look for. how many miles did this happen at? what other problems did you notice besides the misfires at idle?
Old Sep 27, 2005 | 06:47 AM
jrushlow's Avatar
The idle was quite rough but it never stalled or anything. Whenever I pulled the misfire code it was ALWAYS at idle although I had seen the CEL blink at high RPMs before as well (indicates real time misfiring). This started to happen at about 75K miles and I had an accident at about 60K miles where a guy hit me on the left-front. I believe this is what originally caused the cam cover to crack. Other than that the car seemed to run fine... I'm extremely lucky I didn't wreck the engine. There was a pretty big chunk taken out of the timing belt when I removed it.
-Joe
Astafyev26
Mar 7, 2016 11:56 AM
2002wrxlife
Apr 30, 2015 05:56 PM
wrx81
Jan 23, 2006 07:15 AM
joshuagore
Feb 9, 2004 01:55 PM
The Mirror
Jul 20, 2003 10:10 PM
