wot stock fuel map?
Old Oct 17, 2003 | 03:11 PM
Jgrahn555's Avatar
Sarcastic Jackass
Car Info: i drive a beater
What are you using as a fuel pressure regulator? looks like this is the missing link in your equation.
Old Oct 19, 2003 | 04:33 PM
Jgrahn555's Avatar
Sarcastic Jackass
Well, you COULD learn more about your AFC because that will help you our, or you could get a new FPR (adjustable, not rising rate!).
Is this an early legacy engine you've got in there, one of the turbos? If it is, those injectors aren't THAT much larger then stock.
Old Oct 24, 2003 | 02:24 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
You keep refering to a gauge that you're tuning your a/f by. Are you relying on a standard a/f gauge hooked up to a narrowband O2? If so then you're lucky your engine is still in tact. Narrow band a/f sensors are useless in reading any a/f levels except at or near 14.7:1. They are simply inacurate at any other levels. So when your gauge says you're running rich, you might actually be running 13.5:1 or something which is actually too lean.
-- Ed
Old Oct 24, 2003 | 02:26 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
also, in open loop (WOT) the ECU ignores the O2 sensor and relies only on the MAF reading to calculate fueling. The reason for this is stated above
-- Ed
Old Oct 28, 2003 | 02:02 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Bill,
yes, its possible to get a rough tune using a narrow-band while taking other precautions. But its deffinately a lot less safe than tuning with a wideband IMO.
The problem is that as the a/f aproaches richer numbers, the voltage/air fuel curve flattens out very quickly. This means that a slight variation in the recorded O2 sensor voltage corresponds to a fairly large a/f ratio change, making it difficult to predict the actual a/f ratio.
When I was playing around with this exact issue in my SC'd VR6, I found an interesting product. It was just a standard a/f gauge, modified to read a very narrow range of voltages from the O2 sensor in the range of .810-.900v and lit up the LED's apropriately. So basically it was only active during 12.5:1 - 11:1 a/f ratios (guestimate) and attempted to provide similar data to a wideband a/f sensor. I actually bought one and sold the car before I could try it out.
-- Ed
Old Oct 29, 2003 | 04:43 PM
Jgrahn555's Avatar
Sarcastic Jackass
Have you installed an EGT gauge as well?
Old Oct 30, 2003 | 03:23 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Bill,
Indeed, a skilled and knowledgeable tuner such as yourself can get a tune close w/o a wideband. I just want people to understand that its not as easy as looking at a regular narrow-band a/f gauge and tuning based just off that. That gets people in trouble. I think that point has been well established and your input is deffinately beneficial as well. Always enjoy a good tuning chat (especially when its about unorthodox methods ).
-- Ed
Top
