When Should I Get A ECU Reflash?
Old Jan 22, 2004 | 02:35 PM
wrxstipwr's Avatar
Car Info: Soon to be '03 WRX
Question When Should I Get A ECU Reflash?
I have no mods on my subby yet and was thinking of getting the ECU Reflashed but I didnt know if it would be a waste of money or not to get it flashed and then add mods. (didnt know if mods would affect how ECU needs to be flashed) I want to avoid paying to get my ECU reflashed, then getting other mods, then having to get my ECU reflashed to compensate for the new mods. Hope I havent confused you guys. Have heard horror stories about simialar situations and didnt know how true they where. Please help me out. Thanks in advance!
Old Jan 22, 2004 | 04:28 PM
Slack's Avatar
Car Info: '02
Re: When Should I Get A ECU Reflash?
Depends on the route you are planning on taking. I would definitely recommend the ECU Reflash as a first mod, it's great. What you plan on doing later will prob determine what route you should go.
1. If you are wanting to go a custom route(ie. huge turbo, fmic, water injection), high HP, you'd probably be best served sticking to ECUTek or a user tunable ECU such as Utec or Exede. Their advantage is the fact that you can be tuned by an ECUTek dealer(or any tuner for the utec/xede) all over the country. But they have high RE-reflash costs, so it'd be best to wait till you get some mods to get the ECU.
If you plan on going with a pretty much standard upgrade path ie. Up-pipe, Turboback, maybe a bigger IHI Turbo. You would be well served by going with Cobb's Access ECU. Once their accessport comes out (supposed to be by March) you can download a map from their webstie and use that when you get a turboback, or other one of their supplied setups. So no RE-reflash costs. So you could get the ECU first without the additional costs down the road.
madrex
Jun 27, 2003 12:37 AM
russ
May 13, 2003 04:02 PM
kalasend
May 1, 2003 07:19 PM
igorshos
Apr 27, 2003 11:40 PM
BOP
Dec 13, 2002 10:03 AM
