What's the best MBC out there?
Old May 10, 2004 | 11:11 PM
blackwagonrx's Avatar
Anyone know which MBC has the least boost spike?
I was thinking of getting an EBC but can't afford it right now.
Thanks guys
Victor
Old May 10, 2004 | 11:12 PM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
don't do it! NOOOO!
Nick Koan's Avatar
Car Info: Legacy GT
e.) none of the above.
Old May 10, 2004 | 11:15 PM
TurnWRX's Avatar
no clue but everyone seems to like the Joe P mbc
Old May 10, 2004 | 11:17 PM
ok so here's the thing, I had a MBC on my car for about 2 years, and recently even at the lowest level it would spike up to 1.5 bars. So i figured the spring inside is screwed. I changed it back to stock yesterday, and when i floor the boost only goes to .5 bars (about 7-8 pounds) Does this sound right with stock boost? I thought stock WRX's ran at 14 bounds. Anyone know what might be the problem?
Old May 10, 2004 | 11:33 PM
AzN121184's Avatar
Car Info: civic
what gear were u in?
Old May 10, 2004 | 11:36 PM
TurnWRX's Avatar
maybe u wanna post this in the EJ20T section
Old May 10, 2004 | 11:49 PM
my2003wrx's Avatar
Were you in the lower gears? I don't think you can hit 14psi unless you're in 3rd or 4th. Also, maybe you should check your hoses and connections. Does it feel like it's boosting 8psi?
:banana:
Old May 11, 2004 | 12:06 AM
Zee's Avatar
Zee
Car Info: 04 White Aspen WRX
Originally Posted by mexicanpizza
don't do it! NOOOO!
I agree....
NOOOOOO!!!!!!!!!!!!!!
Zee
Old May 11, 2004 | 08:21 AM
go go go's Avatar
Car Info: GF8 ver6
try reset the ecu and have it learn all over again with stock boost solenoid.
Old May 11, 2004 | 09:58 AM
isr96's Avatar
Car Info: 2007 suzuki GSX-R600
why is everyone saying none of the above? just curious?
Old May 11, 2004 | 12:01 PM
WRX_2NR's Avatar
Car Info: 04 WRX
without proper fuel/timing correction don't add boost
Engine = boom!!
1st and 2nd = .05 or 7.5psi
3rd,4th,5th = .1 or 14.7psi
Old May 11, 2004 | 12:25 PM
kravdra's Avatar
Car Info: '99 Impreza OBS
my bad, nevermind
Old May 11, 2004 | 01:59 PM
myroncuz's Avatar
are you sure thats the thread? its about a guy that wants to know if he should get a stick or auto.
Old May 11, 2004 | 11:25 PM
i've tried resetting my ecu but i get the same results. .5 bar at all the gears
