UTEC screwed my car up...
Old Jun 7, 2007 | 10:34 PM
Dirteeboy808's Avatar
Car Info: ?
04 STi Utec
I recently upgraded my UTEC version from 1.0 to 2.3....then reloaded the previous maps and the stock base....now the car runs like crap...sputters and stutters till boost is reached...can't keep idle very well either and bogs during acceleration to boost
I removed the UTEC and it still runs like doodoo or the same as with the UTEC ........tried to reset the ECU by removing ground for over 20 minutes, but runs the same with or without the UTEC attached....please any help is greatly appreciated
PS-followed directions on upgrading version and reinstalling maps to the T......again any help is appreciated
Old Jun 12, 2007 | 08:27 AM
testes1010's Avatar
reflashing the UTEC cannot mess up the ECU, period......
you need to use the old values out of your parameters files BUT use the new Parameter file. Otherwise stuff goes nutty.
What are your mods?
Old Jun 13, 2007 | 11:12 AM
Car Info: ?
TBE that's pretty much it for mods that would affect tuning.........
I figured that flashing the UTEC wouldn't affect or is not supossed to affect the ECU....
so do you have to manually enter the old parameters to the new file?
also I just don't get why after flashing the UTEC the car didn't run well without the UTEC connected, prior to the UTEC installation the car was running fine
Old Jun 13, 2007 | 11:48 AM
testes1010's Avatar
yes.
not sure on the second part. Unless one of the connectors wasn't plugged in well. You did disconnect the battery while removing UTEC correct?
Old Jun 13, 2007 | 11:59 AM
Car Info: ?
crap I think I may have deleted the old perams, do you know where I can get it from?
yes, I took all precautions removed neg. cable, grounded myself before handling, etc, etc.....
Old Jun 13, 2007 | 12:01 PM
testes1010's Avatar
if you were using the stock parameters then just download the parameters file for your 'stg' from www.turboxs.com & send it to the UTEC.
Old Jun 13, 2007 | 12:09 PM
Car Info: ?
I did download the perams to the UTEC, what do yo have to input manually?
Old Jun 13, 2007 | 12:11 PM
testes1010's Avatar
only if you were running different than original parameter would you have to put them in manually.
Old Jun 13, 2007 | 12:24 PM
Car Info: ?
kk, at least we eliminated a considered problem, my friend is coming over to pull codes so we'll see what's up after that...keep it posted
thanks, Mike
Old Jun 13, 2007 | 06:09 PM
Car Info: ?
P0302-Cylinder 2 Misfire Detected
P0303-Cylinder 3 Misfire Detected
Old Jun 13, 2007 | 10:58 PM
taerron's Avatar
correct me if i'm wrong, but cylinder 2 and 3 are not on the same side of the car. 2 and 4 are on the driver side. i will double check this
Old Jun 14, 2007 | 10:09 AM
Car Info: ?
yep, my mistake cylinders are not on the same side......
Raudi
Jul 9, 2007 12:27 PM
minisiu
Jun 17, 2006 02:14 PM
a1cwrx
Sep 1, 2005 06:46 PM
gruppe-s
Jan 28, 2005 06:16 PM
Z1 Performance
Vendor Group Buys/Specials
Jun 2, 2004 12:52 PM
