UTEC for commute
Car Info: 2008 DGM WRX STI
UTEC for commute
Hi, I've had my utec for a couple weeks now. Looking forward to going to stage 2. I have a pretty brutal commute right now, and I was just wondering if anyone had a fuel efficient commuting map. I know there's the valet map, but I was wondering if there was a map out there where you could make 0 boost across the board and then decrease fuel. I've heard of someone who had around 40mpg doing this. Is this even possible? Thanks!
-John
-John
I don't have a map for it but it would be posible to lower peak booste quite a bit... if you had the ability to tune fuel WB02... I would suggest building a map where you close the ABC then set all the numbers in the boost map to 0 and tune the fuel for it... I would be willing to bet this would net you some great gas milleage allthogh you would be **** slow.
Well you can't have 0 boost. You'll have at least 7psi at it's minimum.
Best thing you could as mentioned would be to get a WB A/F setup and play around with your fuel values. Other then that, just turn down your boost and be not so heavy footed.
Z1 Performance
Vendor Group Buys/Specials
Jun 2, 2004 12:52 PM
