tricking the stock ecu
Old Dec 26, 2003 | 01:04 AM
ImprezaRSX's Avatar
Big Baller
Car Info: 93 BG5, 00&01 GM6, 06LGT, 07STi
disconnecting your O2 sensor is a bad idea.
You'll run even worse I promise.
Dump the SAFC.
get an adjustable or programable map sensor.
Your problem is the bigger injectors.
So if you run a split second FTC1 or something like that you can program your map in a way that the computer will not fight or learn around.
Old Dec 27, 2003 | 11:02 AM
Max Xevious's Avatar
BanHammer™
Car Info: 2014 Forester XT
I would think that the ECU learning would help you rather then harm.
also, you sure your ECU in that car learns ? I was under the impression that only OBDII cars were capable of that
Zee
Apr 18, 2006 08:40 AM
Zoeb2s
Jan 27, 2006 12:56 PM
DLN84
Jul 30, 2005 10:41 AM
FostersAFB
Sep 8, 2004 04:04 PM
GottaREX
Wanted
Feb 22, 2004 07:13 PM
