Protune?
Old Oct 10, 2007 | 07:44 PM
Woodward's Avatar
banned
Car Info: 2006 Subaru Impreza WRX TR
Over boost fuel cut is not the same thing as boost creep.
Who said they're the same? One will lead to the other. If you boost creep up above 17.5psi (I believe) for at least a couple of seconds you'll throw a code and experience fuel cut.
Old Oct 10, 2007 | 07:47 PM
Woodward's Avatar
banned
Originally Posted by wrxisthebest
thank u paul....maybe u can help me later!!!
i dont think i have either....but i dont have fuel cut at all!!! and im runnin a stock dp gutted and i thought boost creep only happened on 3" bell mouth dp's or so ive heard!
Any catless turboback exhaust can have boost creep. The size and style of a catless downpipe doens't matter. Who'd you hear that from??
Old Oct 10, 2007 | 09:58 PM
wrxisthebest's Avatar
go to anyplace that sells Catless Dp's online and they have a warning about it!
and they only warn for 2.5l
Old Oct 10, 2007 | 10:07 PM
Woodward's Avatar
banned
http://www.subarureview.com/showreview.php?id=1094
Read the last review. '03 WRX. I've never heard of any half legit retailer warning about having a 2.5L engine.
Any links?
Old Oct 10, 2007 | 10:15 PM
jscspeed.com! i know they have one!
Old Oct 10, 2007 | 10:17 PM
ya...ive heard that that dp doesnt work well all around!!
thanks for the info ryan!
Old Oct 10, 2007 | 10:27 PM
Woodward's Avatar
banned
I have an Invidia dp. Works great and I have a 2.5L.
Old Oct 10, 2007 | 10:29 PM
that exact one...before i bought my car ivan had an invidia v3 on it...now jose has it!!
Old Oct 11, 2007 | 08:15 AM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
In my limited experience tuning Subarus, I have seen "boost creep" manifest itself in the following ways:
1. True Boost Creep.
A slow & steady climb of manifold pressure related directly to engine rpm and is not corrected with recalibrating the ecm. This results in a hp curve that looks like a 45 degree ramp.
The #1 cause that I have seen is due to the restrictor pill being removed/ wrong size restrictor pill. In this case, porting the turbine housing waste gate will not help.
2. "Boost Creep."
Manifold pressure increases normally, then rapidly oscillates by ~5psi. I have seen this exclusively on vf34 turbos. Not saying that all 34s do this, just that all cases that I have dealt with have been 34s. All cases have been corrected with light wastegate porting.
Now on to overboost fuel cut.
The classic example of OBFC is experienced by the driver after removing the factory cat section of the exhaust and not recalibrating the ECM.
Removing the cats allows the velocity of the exhaust gas flow to change quicker than with cats
This allows the turbo to change velocity/pressure faster then the ECM was programmed for.
Since the ecm can't effectively control boost, the rate at which manifold pressure increases to the point that the ecm's max boost trigger is reached.
Old Oct 12, 2007 | 10:07 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
wrxisthebest,
If this is actually Keegan's old car, I tuned it a couple years ago using Ecutek. This is the car that caused all the crazy S-Squared drama back in the day. Anyway, the car had a full catless TBE, UP, and 3-port solenoid at the time I tuned it. If it doesn't have the TBE on now and is still running on the same tune, I would HIGHLY recommend not driving it hard. A tune that's done for a full TBE car is NOT going to run propperly with a stock exhaust!
You also shouldn't be hitting 19psi in 5th gear either way.
Old Oct 12, 2007 | 11:43 PM
well i still have a cbe on it.. and gutted cats!! but im gettin a 3: dp this weekend.. so ill hit u up for a retune hopefuly soon!
Old Oct 13, 2007 | 04:20 PM
Woodward's Avatar
banned
How do you know that your stock downpipe is gutted? Sounds like it had a full TBE then put a stock dp on to pass emissions?
Old Oct 13, 2007 | 07:59 PM
im guessin it is, cause people behind me are always complaining about how it smells bad!!
that or the BOV has basicaaly taken the cats out.. well anyways i should be pickin up a bell mouth dp here real sson so ya!!!
Old Oct 14, 2007 | 12:15 AM
Vladi's Avatar
In Russia, Title Choose You.
Car Info: Everywhere
lol...i dont think you would tell by smell if a car is catted or not....some cars smell more than others, and emit more smoke
Old Oct 14, 2007 | 10:30 AM
well... all the catted cars i know dont smell a whole lot when they hit the gas infront of u!
but when a catless car hits the gas.. damm that **** smells.. its cause there are no cats to take the unburnt gas and instead it just gets put out the tailpipe and it smells alot!
