proECM Powerchip results
Old Aug 27, 2003 | 11:59 AM
Kay95's Avatar
i put the other chip in but still the same thing i think
on my 1.8 when i put my feet to the floor it has more power than it did before, revs better, power was raised alittle through out the rpm range
fuel has not changed but the week before i put a flywheel, new clutch and mounts(revs matching is so fun now)
it did not run rough when i put it in but i have heard other plp say this so it might be common on other years and different ecus
i did notice my temp go up like you described
yes try a ecu reset it might help but the temp will still be there and the roughness does smooth out
???EJ20 in a 2001 impreza???
Old Aug 28, 2003 | 01:23 PM
Kay95's Avatar
ya try some redline waterwetter
oh didnt know you where in the land down under... makes more sence now
Old Aug 31, 2003 | 06:30 AM
Kay95's Avatar
well then im sure you can get a aluminum radiator and that will cool things down if your willing to spend 500 maybe more
Old Aug 31, 2003 | 07:34 AM
Peaty's Avatar
Originally posted by jumper
i dont think there is any water in my radiator. its all coolant. in the Subaru manual it said specifically not to put any water or mix stuff with coolant..
What water isn't a coolant The coolant in there is 50:50 blend of water and anti-freeze (ethylene glycol)
Good info here:
http://members.***.net/gadget/coolant_replacement.htm
Old Aug 31, 2003 | 07:20 PM
Peaty's Avatar
I got a jug of the premixed (50:50 already) stuff in the garage just for topping off every once in a while.
Old Aug 31, 2003 | 07:34 PM
Peaty's Avatar
When I had one in my RS I ran premium. As far as the MPG's mine went down at first mostly because of the way I was driving the car though testing the new chip
Old Aug 31, 2003 | 10:28 PM
Peaty's Avatar
I didn't have any pinging with the 91 myself
Old Sep 1, 2003 | 08:35 AM
Kay95's Avatar
WOW that much of a difference in fuel
i dont think i even noticed a difference but then again i have a 1.8 NA and i started with 93 but you where running 91 why wouldnt you run 98 to help save engine especialy with as hot as the air your car ingests i mean doesnt it get 120F degrees and more down there
