p0304 on a stock 2000 impreza
Old May 25, 2010 | 11:13 AM
goffwind's Avatar
Car Info: 2000 Impreza
I have a stock 2000 impreza 2.2l. In the beginning, if it was damp/raining, the car would miss and the CEL would flash for the 1st minute or less of driving. Then, it would smooth out and be fine. Well, this started getting worse until the CEL stayed on and the engine wouldn't stop missing. I checked the code and it pulled a p0304 misfire on cylinder #4 error. I tried new plugs and wires but no luck. I swapped the #2 & #4 injectors and reset the code. After about 2 miles of driving, the p0304 came back. I looked at the new plugs on the left side and #2 looked like new but #4 was already blackened. I am going to check the compression on #2 and #4 to see if there is much of a difference. However, the way it was acting in the beginning seems more electrical than mechanical. The coil on this car is a single unit. I can see no cracks anwhere in the case on it. Any suggestions on what else to look at? Thanks!
Old May 25, 2010 | 12:11 PM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
HT wires.
Old May 27, 2010 | 02:56 PM
goffwind's Avatar
Umm... aren't HT wires plug wire? I put new ones on and it didn't change a thing.
Old May 27, 2010 | 04:18 PM
iClub Silver Vendor
Doh!
Check your valve clearance.
Siper2
58
May 3, 2006 08:38 AM
jaypowell78
Apr 8, 2005 06:45 AM
stiabuser
Mar 20, 2005 11:32 PM
jaypowell78
Mar 10, 2005 07:29 PM
schafer
Nov 13, 2004 10:06 PM
Top
