Outback / Impreza 2002 OBDII Compliant or not?
Since the old forums can't be searched anymore i'll ask the question.
Are the Outback 2002 and Impreza 2002 OBDII compliant.
Are they using the ISO standard or another one.
The reason I ask is that i've been unable to read OBD codes from 2002 subarus.
I visually checked the metal pins available under the dash, and they don't seem to follow any standard (mind you they are really hard to see ??? ) plus inside the hood, no mantion of OBD II compliance. Just a mention follows MOT 2002 specifications.
The same laptop used with the GM interface works perfectly, so I know the laptop and cables are fine.
Superglue WRX
Oct 29, 2006 01:22 PM
UM-WRXer
May 7, 2004 07:53 PM
WRX44
Jan 31, 2003 10:54 AM
iON Performance
Jan 29, 2003 05:22 PM
