No boost for you!
Old Jun 2, 2005 | 09:33 PM
2fcknfst's Avatar
Car Info: 2002 3/4 ton Cevy Suburban, 1997 Integra Type-R, 2004 WRX-STI
No boost for you!
Hey everyone...
K, turbos are new to me, and I am having one helluva time trying to figure this one out:
Problem:
Car will not boost beyond WG tension spring, so with the Tial 38mm WG, I see a consistant 10-11psi. Initial problem was the lines on the top of the WG and side were reversed - although highly entertaining, I didn't think the motor would last too long pushing 30psi. So after correcting that, I discovered that the 4mm vacum line on the HKS evc 2 was in fact hooked up to the same vacum port that the fuel regulator was - correcting that problem gave me almost 1.0 bar more of fuel pressure. I have gone through all lines, reset the EVC, checked the filters etc etc etc.
One thing that did come to mind was insuring that the stock BC was in fact disconnected... however, I am not sure how to verify that.
I do not think there is anything wrong with the EVC - it does not throw any errors, appears to work, display works etc.
A buddy and myself have just spent the last couple of hours trying to figure this out, but we are at a loss.
Any input here would be greatly appreciated.
Cheers
Old Jun 3, 2005 | 04:09 PM
2fcknfst's Avatar
Disaster avoided... found my boost...
Wow.
Old Jun 3, 2005 | 04:18 PM
Wingless Wonder's Avatar
What was the cause of the problem?
Old Jun 4, 2005 | 11:51 AM
2fcknfst's Avatar
Unknown; I took the entire system apart, then put it back together and all of a sudden it worked...
Lowend
Sep 8, 2005 10:47 PM
yzercyber
Aug 12, 2005 03:42 PM
spdkills
Mar 10, 2003 08:31 PM
ShokWaveRider
Feb 21, 2003 06:14 AM
XwrxX
Dec 17, 2002 07:14 AM
