Misfire HELP!
Old Feb 6, 2003 | 02:07 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
Misfiring in 3 cylinders in unlikely.
Let me guess, do you have a lightened flywheel or an aftermarket clutch?
Old Feb 7, 2003 | 10:34 PM
ImprezaRSDriver's Avatar
Because the amount of weight that is placed on the crankshaft I believe, because when you lighten the flywheel, it changes the dynamics of the engine a bit and make the engine a little "looser" if you will. I would also assume that the harmonics change also. Because like underdrive pulleys, the weight of the flywheel and pulley is designed to work such that it acts as a harmonic dampener.
It is like saying, I have misfires on all four of my cylinders. But is it really misfiring? I do not think so. Subaru is supposed to come out with a reflash for the misfiring issue.
Here is a good article about underdrive pulleys:
http://www.dinanbmw.com/html/danger_...er_pulleys.htm
Siper2
58
May 3, 2006 08:38 AM
SubeeTedII
Dec 15, 2004 03:16 PM
wonton2049
Nov 14, 2004 03:25 PM
bluemax
Oct 28, 2003 01:39 PM
in3g_wrx
Sep 8, 2003 01:34 AM
