MBC Help !~ Please !~
Old Dec 3, 2003 | 01:31 PM
mario's Avatar
Talking
If you don't understand this LMK because it is pretty Basic as it gets. the Stock boost seleniod w/ the 2 hose outlets should be taped up so no dust gets inside. and make sure you keep the seleniod pluged in to the harness so you don't get a CEL. And if you have anymore Q's installing anything check the site i gave you out enjoy and i hope you have a boost gauge first before you perform this mod.
http://www.scoobymods.com/forums/sho...=&threadid=729
Old Dec 3, 2003 | 04:48 PM
RussB's Avatar
Car Info: $200,000 sports car
Can you post a link to the MBC that you bought? The diagram you show in your second post is correct for a BALL VALVE mbc. if it's a bleed valve mbc you'll need to do it differently.
Old Dec 3, 2003 | 07:32 PM
mario's Avatar
Your second diagram does look good but like russ said which do you have??
Old Dec 3, 2003 | 07:43 PM
RussB's Avatar
can you post the instructions it came with? or a link to them?
Old Dec 4, 2003 | 10:45 AM
mario's Avatar
Wunder,
I can not believe how complicated this thing is?!?!
I donot have any experience working w/ a VBC. Do you have a manual boost contoller? or do you just have a t-fitting and some hoses??LMK
Old Dec 4, 2003 | 10:59 AM
RussB's Avatar
yeah, that last diagram looks like how to do it. it's a bleeder valve that you have. The wrx ALREADY has a T in place, and it also has an orifice in the hose from the turbo to the T. If you have some spare hose and stuff, you might want to try the factory T and orifice and then try the HKS stuff to see what works best, but I'm sure the stock WRX orifice is sized for the stock turbo. Not sure how MBC's work on 04's or STI's though, you might want to do a search on here.
Old Dec 4, 2003 | 04:33 PM
RussB's Avatar
yeah, the key is that it DOES bypass the stock controller. if you ran it inline with the stock controller, it will actually restrict your boost.
Old Dec 18, 2003 | 05:44 AM
theworx's Avatar
Car Info: 04 Java Black Sedan
Word of caution, be careful with that thing. I have an 04 WRX and just took my MBC off last night due to problems I was having. I only saw a max of 16 psi, but it was surging and hesitating and bucking sometimes. Put it back to stock and everything was fine, plus it felt faster. I felt like the ECU was constatnly pulling timing. I am more comfortable running my car without it.
