Knock detection
Old Jun 3, 2006 | 04:48 AM
haymailme's Avatar
Car Info: 02 wrx wagon - stage2 access port
Knock detection
Does anyone know of a cheap way to detect and/or record knock (other than listening for it)?
Is there some type of obd2 software I can run on a laptop?
I also have an access port and an obd2 scanner available
Old Jun 4, 2006 | 09:15 PM
ars636's Avatar
Tari
Ecu explorer from tari will log your knock through the obdII port with the accessport cable. you can get ecu explorer here http://www.tari.co.za/download/insta...er.v3.0.25.exe
Old Jun 6, 2006 | 09:55 AM
wow good info
yeah other than some kind of aftermarket knock sensor or utec or a stand alone you have to listen for it
Old Jun 6, 2006 | 01:02 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
FYI, the "knock signal" field as reported by the ECU is close to useless. The only time it will report actual knock is if it happens exactly at the same time as the software is recording the data sample. Considering the relatively slow sample rate of the software and relatively high frequency of knock, it is not likely that the two will coincide. The only way to tell if there is knock from logs is by looking at the knock correction field and referencing it to the actual dynamic advance table. The problem with that is that you have to have access to your actual map, so only the tuner can actually know for sure.
4080wrx
Aug 21, 2011 04:36 PM
turfshark
Apr 4, 2011 09:34 AM
Rivers
Oct 7, 2009 05:35 PM
Kevin M
Jan 26, 2007 04:32 PM
Top
