injen intake makes cel light come on?
Old Jun 28, 2003 | 03:53 PM
Fantabulous's Avatar
well i believe if you remove your maf sensor the cel will automatically turn on... if it stays on after you clear the code.. i dont know... imo i dont like cold air intakes, i stick with the factory.
Old Jul 1, 2003 | 07:41 PM
ImprezaRSDriver's Avatar
Have the code pulled and see if it really is the intake. What other mods do you have on your car? Because it is unlikely that the intake is causing misfires.
Old Jul 4, 2003 | 09:27 PM
WREXXED's Avatar
Car Info: 2002 WRX
Dude, I used a Injen intake for a good year w/ no problems. It will not cause a CEL. Check your installation of the MAF sensor, maybe you put it on backwords...i've heard this has happened to others before and caused a CEL. Get the code pulled and see what it is.
I wouldn't worry about it the injen your car should be fine w/ it. Now if you eventually get some type of management make sure it's tuned for it.
sigma pi
29
Aug 1, 2008 07:47 PM
Max Xevious
Jan 7, 2005 06:24 PM
digitsti
Mar 29, 2004 03:40 PM
EtchyLives
Mar 24, 2003 03:33 PM
