HKS SSQ BOV Kit parts?
It's a very simple piece. Just a thin piece of metal triangularly shaped, with holes cut for air from the IC, and the 2 12mm bolts. I bought a sheet of ungalvanized steel and just traced the shape of the stock flange, and cut it out. The BOV welds onto the flange, which bolts onto the IC. You can even use your original gasket, just be careful not to bend it. Good Luck man.
JunGdB
14
Jun 18, 2005 03:59 PM
nu02wrx
May 26, 2004 12:04 PM
