High alt. and lag
Old Jul 13, 2003 | 06:56 PM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
Well being at that altitude, you kinda are out of luck. My 15psi at sea level is only about 11-12psi at your altitude. No matter how you look at it, your boost levels will be less when the air is thinner. But do not assume that you can just up the boost as you will make the turbo over work itself more then likely and perhaps it will prematurely die. If you were to push 15psi at that altitude, you would be at 18-19psi at sea level and would be way past the turbo's efficiency level.
With that said, I would give www.dyno-comp.com a call and see what Clark can do for you. Or even www.cobbtuning.com and see what they have as well. Their ECU reflashes may be just the ticket.
Old Jul 20, 2003 | 04:40 PM
ish's Avatar
ish
i put my first 20,000 miles or so at above 7000 feet and never had a problem with power, or too much lag
Imported209
Jul 31, 2010 07:34 AM
hamburgl3r
Oct 9, 2009 08:56 PM
wkdwrx02
Jun 9, 2007 02:09 PM
boomer
Mar 27, 2005 07:28 AM
RIScoob
Aug 29, 2003 09:06 AM
