Help PLEASE DAD put wrong GAs in ('03 WRX).
Old Oct 13, 2005 | 06:42 PM
Nettalp's Avatar
Question Help PLEASE DAD put wrong GAs in car.
I have a 2003 WRX and my Dad put 87 in my car one day and I drove on it for about a 1/2 tank with it not knowing. But my question is my car feels a little slower what happened and how do I fix it????
Thanks,
Doug
Old Oct 13, 2005 | 06:47 PM
EJ_20's Avatar
Car Info: Impreza 2.0
Thanks,
Doug
use higher oct# for the next fill and you will be okay
Old Oct 13, 2005 | 06:53 PM
VRT MBasile's Avatar
one tank...you'll be fine...running the car on lower octane for a long time would be bad...but you'll be safe. if you are nervous, fill the other half of the tank with 91....it'll average out to 89
Old Oct 13, 2005 | 07:07 PM
bpang1's Avatar
Car Info: '04 WRX Wagon
Dude your car is FUBAR!
Holy crap! I can't believe your dad did that to you...you're car is basically gonna die in about 40-50 miles. Good luck on that engine rebuild.
Just playin'
Old Oct 13, 2005 | 07:08 PM
bpang1's Avatar
You could probably go right now and throw in a good octane booster and fill the rest of the tank with premium and you should be fine.
xenophobe2020's Avatar
correct me if im wrong but cant you buy some octane booster to mix with lower octane gas to get it up to where it should be. do a search on google or yahoo for it, i think you can buy it at any autoparts store.
edit:
dammit, beat me to the punch, i hate it when that happens.
Old Oct 13, 2005 | 07:11 PM
A.V.E.'s Avatar
use either octane booster or 100 octane
-Ave
Old Oct 13, 2005 | 08:26 PM
Nettalp's Avatar
Talking Thanks guys
I will do fix it good lookin out
Old Oct 14, 2005 | 03:56 AM
Wingless Wonder's Avatar
Moved thread from General to Engine Management forum.
87 Octane in a WRX.
Old Oct 14, 2005 | 04:43 AM
sykosis's Avatar
If you can find some, throw a couple gallons of 100+ octane race gas to even things out.
And once you have good fuel, reset the ECU (disconnect the battery) so it relearns properly
Old Oct 14, 2005 | 05:46 AM
1reguL8NSTi's Avatar
Car Info: 05 STi
Yeah you'll be fine. Just try and stay off boost until this tank is burnt out due to knock reasons. If you're really that worried about it you could use an MMT based octane booster. I used the NOS not-street-legal variant and it def. works.
Old Oct 14, 2005 | 11:17 PM
I was really out of it today and accidentally put in 87 :-\ I went to AutoZone and got some STP Octane Boost and put it in when I got home...hopefully everything will be ok though
Old Oct 15, 2005 | 03:48 AM
Just take it easy on the throttle until the tank of fuel is low enough to fill up with premium again. The only drawback to topping off a tank of 87 octane with a bottled booster is that it doesn't mix as thoroughly as adding the booster first, then pumping the gas.
Old Oct 15, 2005 | 10:57 AM
sounds like a plan....a vevry boring plan...but a plan
Old Oct 29, 2005 | 10:44 PM
blurexwagon's Avatar
Car Info: '05 WRX Wagon, some goodies...
Wink White Sox must have won it ALL...
...mind you, I gotta be impressed that your DAD put gas into YOUR car, has that happened to any of us EVER...?
iLoqin
Dec 3, 2010 11:10 PM
red wrx
Nov 26, 2006 07:35 AM
Max Xevious
Oct 28, 2005 12:05 AM
gil
Jul 27, 2005 01:41 PM
Sti-nkinPhast
Oct 7, 2003 10:54 AM
