Help, cars running like crap
Old Mar 17, 2003 | 02:04 PM
mikey_750's Avatar
Car Info: 2002 WRX
I swapped out the Headers uppipe and DP, and ever since I changed them the car does not seem to hit any boost. It's real slow. I have the uppipe fix on, and no check engine light. Can my car not make boost now due to these mods, it doesn't sound like it, but something is drastically wrong. It idles fine, and now it just seems the turbo isn't working right. GT spec header Perrin uppipe and DP. Can someone please help. Any suggestions would be helpful. Can my ECU be screwed up due to these changes? I'm desperate.
Old Mar 17, 2003 | 02:26 PM
mikey_750's Avatar
Car Info: 2002 WRX
its a 2002 WRX 5000 miles
I'm going to try and reset the ECU overnight. But any help would be greatly appreciated.
Old Mar 17, 2003 | 10:00 PM
one2three's Avatar
Car Info: 02 Sil Rex
I have a very alike setup, GT Spec header w/up pipe, perrin DP and stock catback. I ran into the same problem. I was only able to make ~10 lbs of boost. After redo the whole installation 3 times and fix all those minor exhaust leak, I am all back to normal and boosting 16lbs. Look for gas leak and the sooner you take care of that, you shall be fine
Old Mar 18, 2003 | 09:17 AM
mikey_750's Avatar
Car Info: 2002 WRX
Fixed
The Perrin DP, which I originally thought was the **** caused all my problems. No leaks, but the flange between the DP and the wastegate dump was not set up correctly, and my wastegate got stuck on it, and was stuck open. Anyway after a little grinding and poloshing, exerything went back together sweet, and it runs like a dream. Well a loud *** dream.
iammedan
Mar 21, 2013 12:12 PM
mmboost
Dec 22, 2004 07:32 PM
TheOmega
Nov 20, 2004 10:11 PM
gpatmac
Mar 4, 2004 06:34 AM
