Greddy Profec-B Spec II HELP
Old Aug 30, 2003 | 06:09 PM
MyRuRex's Avatar
Car Info: '02 PSM WRX Wagon
Unhappy Greddy Profec-B Spec II HELP
Just installed this baby. Looks awesome....mounted right above the steering wheel column. I took out the "P" switch.
BUT...how the heck do you set up this thing???
Lo/Hi boost is not working right....I'm getting higher boost in the Lo setting eventhough the Hi setting is set higher. The directions that came w/this are worth ****ake
I have a Unichip Stg 1......was set at 1.1 bar (~16psi) w/the MBC
The problem w/this is that the settings is based on percentage....it's not making sense. I set it @ 100% and that goes way up to about 1.5 bar at part throttle in 1st gear!!! When I turn it down......I can't even get up to stock boost (~14.5psi)!!
What's up
Another problem is.....My BOV isn't blowin off!! My guess is I have to many T's in that area.....It's like a LA freeway in the BOV area. I also have a mechanical boost gauge in that area.....
I know I'm just yappin away but HELP !!!!!!
Old Aug 31, 2003 | 06:58 AM
MyRuRex's Avatar
Old Aug 31, 2003 | 10:02 AM
NluvwithXLR8ing's Avatar
this might help: http://www.2gnt.com/nuke/modules.php...wcontent&id=34
dgp2003wrx
Apr 30, 2005 07:31 PM
peewee111
Sep 13, 2003 07:59 PM
ctdragon
Aug 31, 2003 02:11 AM
NRTmotorsports
Aug 7, 2003 08:15 AM
NRTmotorsports
Aug 4, 2003 05:31 PM
